Backup immediately fails
BubberDucky
Post by BubberDucky » Fri Apr 04, 2025 3:59 pm
Edit (Solution): Was trying to write to a drive that did not exist. Apparently makemkv does not tell you that directly.
I could use some help. After a month long hiatus, before which I could backup Blu Ray without problems, I have now two new separate Blu Ray discs.
For both, the backup immediately fails. Can anyone help?
Debug log started at Fri Apr 04 15:55:38 2025 , written by MakeMKV v1.17.9 win(x64-release)
001005:0000 MakeMKV v1.17.9 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:[redacted]
DEBUG: Code 3 at p3dF_g|OCYM]UJKb%>GKhPFX:29395310
SDF  v098: PIONEER_BD-RW___BDR-UD04_1.14_
001011:0000 Using LibreDrive mode (v01.0 id=489CDFD6D392)
005072:0000 Backing up disc into folder "file://
DEBUG: Code 2147483648 at 5o[KeC_%cwVJ\0Z+:121265499
001003:0020 DEBUG: Code 0 at iK@-)Jpto6aCn!YH=2R:29396345
001003:0020 DEBUG: Code 0 at r79-F\`Qopn&7y,}?R%):29397426
005069:0080 Backup failed
Application exited at Fri Apr 04 15:57:34 2025
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8A10
Firmware version: 1.14
Disc Information
Label: DIE FRAU IM NEBEL
Timestamp: 2023-03-29 10:28:41
Protection: AACS v68
Data capacity: 42.47 Gb
Disc type: BD-ROM
Number of layers: 2
Re: Backup immediately fails
Post by dcoke22 » Fri Apr 04, 2025 10:35 pm
Try gently cleaning the discs, even though they're brand new. Sometimes there's something on a brand new disc that's invisible to the eye but makes reading it difficult for the optical drive.
BubberDucky
Post by BubberDucky » Sun Apr 06, 2025 8:42 am
Sadly, this doesnt help. I often could alleviate errors during the backup by cleaning the disc, but this immediate failure is new. I tried multiple discs.
Could it be a drive problem?
BubberDucky
Post by BubberDucky » Sun Apr 06, 2025 9:02 am
Well, I am officially a dumbass. I was trying to write to a drive which I hadnt plugged in.
A bit weird that makemkv does not just tell me that is the issue.
Case closed!
