Hi I am new to UHD i have a BW-16D1HT That i have flashed with firmware from this site
now i can write to hard drive and it works very well,
can anyone please tell me how i can play from the main UHD Disk, if i can not why is this,
Thanks Davebb
New to UHD Playing from disk
Re: New to UHD Playing from disk
UHD encryption needs keys to play, and your choice of software determines whether or not you have keys. The official way involved having specific hardware and software (Windows, a compatible drive, cabling that blocked being able to tap into the video signal, a compatible display, a particular program to view). Unofficial ways have been to use software that has its own keys, and players that are compatible with playing as that software decodes the video. Or, writing the video out in standard files and playing it later.
Real-time play is difficult, because of this.
ok thanks, does the film makers not want the uhd film disks not to pay on a computer ?
only to play on a home cinema player
thanks Dave
thanks Dave
You can play the discs "unofficially" using a player such as VLC, MPC-HC etc that you have integrated with MakeMKV (in preferences) so that MakeMKV can be used to decrypt the disc on-the-fly.
Thanks i am now using VLC PLAYER
Thanks Dave
Thanks Dave
