MakeMKV v1.17.9 Darwin with newest MacOS Sequoia 15.4 - the macOS was just released 24 hours ago and maybe the problem.
I am using a MacBook Air M1 2020 16 GB RAM and 1 TB drive with no prior problems with MakeMKV until today.
I even deleted the MakeMKV program and redownloaded it and get the same error.
any suggestions?
Keep getting fatal error occurred, program will now exit
RobKh
Re: Keep getting fatal error occurred, program will now exit
There's a MacOS section of this forum and one of the top threads in it is this one: https://forum.makemkv.com/forum/viewtopic.php?f=4&t=37090
If you read through it, you'll find this post: https://forum.makemkv.com/forum/viewtopic.php?p=171869#p171869 where MakeMKV's author, Mike, states that an update will be available in a few days.
RobKh
Thanks...I will wait for update on Mac side and MakeMKV side.
Vintrus
Im having the exact same issue under windows neither of my LG drives are working and I am using 1.18 both drives.
Try version 1.18.1.Vintrus wrote: Sat Apr 05, 2025 3:36 pm Im having the exact same issue under windows neither of my LG drives are working and I am using 1.18 both drives.
