Asus BW-16D1X-U
Ptitvert
Re: Asus BW-16D1X-U
#196 Post by Ptitvert » Mon Mar 31, 2025 8:08 pm
Billycar11 wrote: Mon Mar 31, 2025 7:59 pm
Ptitvert wrote: Mon Mar 31, 2025 7:56 pm Hi everyone,
I've just got this drive:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
Firmware date: 2020-07-21
Firmware version: ID76
Could you help me how to "flash" or "LibreDrive" it?
Thank you very much in advance for your help.
sure email me for a flasher
email sent
tony.riviere
Re: Asus BW-16D1X-U
#197 Post by tony.riviere » Thu Apr 03, 2025 10:09 am
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: D***********
Highest AACS version: 81
Hi, newbie here. First post. I notice this is very similar to previous ones. Is it OK to PM for details of flashing the drive? I'm on the latest Mac OS.
Thanks in advance.
Re: Asus BW-16D1X-U
#198 Post by Billycar11 » Thu Apr 03, 2025 11:18 am
tony.riviere wrote: Thu Apr 03, 2025 10:09 am Drive Information
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Thanks in advance.
sure email me that info see below
Ptitvert
Re: Asus BW-16D1X-U
#199 Post by Ptitvert » Thu Apr 03, 2025 6:40 pm
Ptitvert wrote: Mon Mar 31, 2025 8:08 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ...
email sent
Just wanted to say "Thank you" to Billycar11 :-) it works like a charm! and for the record, here is the corrected drive info now after the flash :-)
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number: ...
Drive platform: RS8F01
Firmware version: 1.01/ID72
:D
Now just waiting for the latest version of makeMKV that works with the new macos 15.4 :-) and life will be perfect again :-D
drwhotoo
Re: Asus BW-16D1X-U
#200 Post by drwhotoo » Fri Apr 11, 2025 5:49 pm
Hey All,
I'm not having any luck with this. Can anyone offer some guidance?
Here's my MakeMKV driver info:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: ...
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Highest AACS version: 75
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
It's a 2021 drive on a Mac (MacBook Air M2 chip, Sequoia 15.4) connected via USB-C
That's the drive info after I attempted to flash it with the Terminal.
xxxxx-MacBook-Air:MacOS mcclayton$ ./makemkvcon f -d /IOBDServices/F0D08170 -f /Users/xxxx/Desktop/sdf.bin rawflash enc -i /Users/xxxx/Desktop/ASUS-BW-16D1H-U-A204-WM01001-211901041044.bin
Reading input file /Users/xxxx/Desktop/ASUS-BW-16D1H-U-A204-WM01001-211901041044.bin
Current Drive ID: ASUS_BW-16D1X-U_A104_211901041047_KLZL4TE4954
yes
100% Operation finished
Done successfully
After flashing, I restarted both the drive and MakeMKV and there's no change in the drive info. Any pointers?
Re: Asus BW-16D1X-U
#201 Post by MartyMcNuts » Fri Apr 11, 2025 11:28 pm
drwhotoo wrote: Fri Apr 11, 2025 5:49 pm Hey All,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: ...
yes
Done successfully
Firmware is not encrypted so change enc to main.
drwhotoo
Re: Asus BW-16D1X-U
#202 Post by drwhotoo » Sat Apr 12, 2025 1:46 am
Damn! I can't believe that worked. Thanks so much!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A204
Serial number: ...
Firmware date: 2119-01-04 10:44
Firmware version: 0.A204W
spiritofxxc
Re: Asus BW-16D1X-U
#203 Post by spiritofxxc » Mon Apr 21, 2025 1:40 am
Hi everyone, I got this drive second-hand, and I'm wondering if it's possible to be patched to enable 4k support. Can somebody point me in the right direction?
This is the drive info:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: ---
Firmware date: 2015-10-20
Highest AACS version: 63
Drive platform: RS8600
Firmware version: E101/ID76
Re: Asus BW-16D1X-U
#204 Post by Coopervid » Mon Apr 21, 2025 10:19 am
spiritofxxc wrote: Mon Apr 21, 2025 1:40 am Hi everyone, I got this drive second-hand, and I'm wondering if it's possible to be patched to enable 4k support. Can somebody point me in the right direction?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: ---
PM sent.
spiritofxxc
Re: Asus BW-16D1X-U
#205 Post by spiritofxxc » Mon Apr 21, 2025 3:53 pm
Coopervid wrote: Mon Apr 21, 2025 10:19 am
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: ---
PM sent.
Thanks a lot! It worked perfectly!
leifeng
Re: Asus BW-16D1X-U
#206 Post by leifeng » Sun May 04, 2025 9:54 am
hello guys,I need some help to flash my drive
This is the drive:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Drive platform: RS8F00
Firmware version: E116/ID71
Re: Asus BW-16D1X-U
#207 Post by Coopervid » Sun May 04, 2025 8:47 pm
leifeng wrote: Sun May 04, 2025 9:54 am hello guys,I need some help to flash my drive
This is the drive:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
leifeng
Re: Asus BW-16D1X-U
#208 Post by leifeng » Mon May 05, 2025 3:26 am
Coopervid wrote: Sun May 04, 2025 8:47 pm
This is the drive:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.
thank you,it can work now
MysticWizard
Re: Asus BW-16D1X-U
#209 Post by MysticWizard » Sat May 10, 2025 2:12 pm
Back when I bought my external drive, I was dissapointed to find out it was not UHD friendly, some even claimed it could not read UHD bc hardware was not present. Decided today to see if anything changed and am unsure if it has. Here's my drive info, still no UHD?
Also if it is possible, will I lose the capability to write 100GB M-Disks?
Thanks for your time!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number:
Firmware date: 2019-03-07
Firmware version: E115/ID71
Re: Asus BW-16D1X-U
#210 Post by Coopervid » Tue May 13, 2025 3:02 am
MysticWizard wrote: Sat May 10, 2025 2:12 pm Back when I bought my external drive, I was dissapointed to find out it was not UHD friendly, some even claimed it could not read UHD bc hardware was not present. Decided today to see if anything changed and am unsure if it has. Here's my drive info, still no UHD?
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number:
PM sent. You will just add capabilities.
