Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: DDDL535253WL
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8511
Firmware version: 1.14
I don't suppose I could ask for the same assistance if possible? I feel bad literally just posting the above info and expecting a reply.
Would really appreciate your assistance, thank you.
Matt.
Pioneer BDR-UD03 UHD possibility
louisefindlay23
Re: Pioneer BDR-UD03 UHD possibility
I'm having a similar issue. Can you let me know what you did to fix the Drive and firmware hardware types don't match error? https://imgur.com/a/47Rg7gA
Thanks.
Are you sure that no disc was in drive and tray was closed?louisefindlay23 wrote: Tue Apr 01, 2025 11:38 amI'm having a similar issue. Can you let me know what you did to fix the Drive and firmware hardware types don't match error? https://imgur.com/a/47Rg7gA
Thanks.
PM sent.Schbeemb wrote: Sun Mar 30, 2025 8:29 am Drive Information
Revision: 1.14
Matt.
PM sent.wallybuys wrote: Sun Mar 30, 2025 2:34 am I have had a Pioneer BDR-UD03FAL sitting around, I managed to get a case for it. It looks like I need to cross flash it (to a UD04?) in order for it to read Blu-Rays?
See attached MakeMKV output, and I have a PC to do any required flashing.
Drive Information OS device name: /dev/sr2 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.03 Serial number: Firmware date: 2015-05-14 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8510 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.03/ID19 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
louisefindlay23
Yes. I've just double and triple-checked and there's no disc in the drive and the tray is closed. Using Windows 11 as the OS and plugged both USB ports into 3.0 ports if that helps.Coopervid wrote: Tue Apr 01, 2025 4:38 pmAre you sure that no disc was in drive and tray was closed?louisefindlay23 wrote: Tue Apr 01, 2025 11:38 amI'm having a similar issue. Can you let me know what you did to fix the Drive and firmware hardware types don't match error? https://imgur.com/a/47Rg7gA
Thanks.
Last edited by louisefindlay23 on Wed Apr 02, 2025 12:08 pm, edited 1 time in total.
zittrig
Generally asked:
Are there any differences between
- BDR-UD03
- BDR-UD03B
- BDR-UD03TBD
Are the B and TBD flashable to BDR-UD04 like the BDR-UD03 when the firmware is older then 12/2022?
MakeMKV information not available, but perhaps there are any empirical values?
I could get one of them for a friend who has an empty enclosure since his BU40N is gone.
- BDR-UD03
- BDR-UD03B
- BDR-UD03TBD
Not really. The only thing seems to be the firmware version should be 8510 or 8511. It looks like 8591 (see above) is not flashable. Maybe the author forgot to add this or nobody has it tried before so 8591 is excluded.zittrig wrote: Wed Apr 02, 2025 7:35 am Generally asked:
- BDR-UD03
- BDR-UD03B
- BDR-UD03TBD
Read your PM.louisefindlay23 wrote: Tue Apr 01, 2025 9:09 pmYes. I've just double and triple-checked and there's no disc in the drive and the tray is closed. Using Windows 11 as the OS and plugged both USB ports into 3.0 ports if that helps.Coopervid wrote: Tue Apr 01, 2025 4:38 pmAre you sure that no disc was in drive and tray was closed?louisefindlay23 wrote: Tue Apr 01, 2025 11:38 am
Thanks.
zittrig
Ok, thanks for your reply!Coopervid wrote: Wed Apr 02, 2025 12:12 pmNot really. The only thing seems to be the firmware version should be 8510 or 8511. It looks like 8591 (see above) is not flashable. Maybe the author forgot to add this or nobody has it tried before so 8591 is excluded.
louisefindlay23
Many thanks. I appreciate your help. I've responded (I think). The quote icon is to reply? Anyway, I'd like to try it.Coopervid wrote: Wed Apr 02, 2025 12:13 pmRead your PM.louisefindlay23 wrote: Tue Apr 01, 2025 9:09 pmYes. I've just double and triple-checked and there's no disc in the drive and the tray is closed. Using Windows 11 as the OS and plugged both USB ports into 3.0 ports if that helps.Coopervid wrote: Tue Apr 01, 2025 4:38 pm
FYI- I was told the 8591 firmware belongs to a BD combo ( can't write BD-R). Therefore this hardware can't be flashed with a BD-writer firmware.
louisefindlay23
Thanks for the information and getting in touch. I've replied to your PM with the specific link and product name which does include BD Combo. Is there any combo firmware available or do you need a writer?Coopervid wrote: Thu Apr 03, 2025 9:14 am FYI- I was told the 8591 firmware belongs to a BD combo ( can't write BD-R). Therefore this hardware can't be flashed with a BD-writer firmware.
There is no Pioneer combo that can be flashed to be UHD capable.louisefindlay23 wrote: Thu Apr 03, 2025 4:16 pmThanks for the information and getting in touch. I've replied to your PM with the specific link and product name which does include BD Combo. Is there any combo firmware available or do you need a writer?Coopervid wrote: Thu Apr 03, 2025 9:14 am FYI- I was told the 8591 firmware belongs to a BD combo ( can't write BD-R). Therefore this hardware can't be flashed with a BD-writer firmware.
louisefindlay23
Thanks for letting me know. I appreciate you looking into this for me.Coopervid wrote: Thu Apr 03, 2025 4:22 pmThere is no Pioneer combo that can be flashed to be UHD capable.louisefindlay23 wrote: Thu Apr 03, 2025 4:16 pmThanks for the information and getting in touch. I've replied to your PM with the specific link and product name which does include BD Combo. Is there any combo firmware available or do you need a writer?Coopervid wrote: Thu Apr 03, 2025 9:14 am FYI- I was told the 8591 firmware belongs to a BD combo ( can't write BD-R). Therefore this hardware can't be flashed with a BD-writer firmware.
