Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
Re: Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
#991 Post by Billycar11 » Mon Mar 31, 2025 1:46 am
2 ubks in stock now
use links proved in emails to purchase.
All gone
Jake-E
#992 Post by Jake-E » Mon Mar 31, 2025 3:02 pm
Forgot to update, my drive shipped fast and was packaged box in a box.
The Pioneer made short work of the 3 UHDs that my libredrive flashed LG didn't like: John Wick 4, They Live, The Thing.
Thanks Billycar11.
FoxWing59
#993 Post by FoxWing59 » Tue Apr 01, 2025 8:25 pm
Wanted to say thanks to Billy for providing the Pioneer drives. I've bought some over the past year and they've all been great, none have had an issue at all with any of my discs.
ForTheFallen
#994 Post by ForTheFallen » Wed Apr 02, 2025 2:41 am
Billycar11 wrote: Mon Mar 31, 2025 1:46 am 2 ubks in stock now
Still have the 2 s13ubk’s in stock?
skelt11
#995 Post by skelt11 » Wed Apr 02, 2025 1:38 pm
I received my drive from Billy today. Supper fast response to my emails and fast shipping. I mounted the drive up in the OWC case (mounting bracket trick worked great), and it worked perfectly on my first go. Now I need more to speed things up.
PeterMac
#996 Post by PeterMac » Thu Apr 03, 2025 12:34 pm
Billycar11 - do you shipping to Poland ?
Have a question about BDR-213, which is latest firmware from Pioneer which work with MakeMKV to rip UHD BD ?
#997 Post by Billycar11 » Thu Apr 03, 2025 12:57 pm
PeterMac wrote: Thu Apr 03, 2025 12:34 pm Billycar11 - do you shipping to Poland ?
Sorry no I'm USA only asmcom has Europe covered
PeterMac
#998 Post by PeterMac » Thu Apr 03, 2025 7:38 pm
Too bad :(, maybe czary2mary will have something
Question about crossflashed Pioneer drives let's say BDR-212EBK to S12J-X to be MakeMKV Libredrive supported.
Does that drive crossflashed are same and 100% compatible with play UHD BD discs with PowerDVD ? or it's not same as real S12J-X ?
#999 Post by dcoke22 » Thu Apr 03, 2025 9:25 pm
PeterMac wrote: Thu Apr 03, 2025 7:38 pm Too bad :(, maybe czary2mary will have something
Since Intel deprecated SGX in their CPUs, Cyberlink has removed the ability to play UHDs in PowerDVD 22 and later. If you have a version that currently still works, it isn't a real long term solution.
KENSAI
#1000 Post by KENSAI » Sun Apr 06, 2025 12:19 am
Am I reading your post correctly that there are no slimline enclosure options? Just the hulking 5.25" enclosures? They're so...BIG. :lol:
#1001 Post by Billycar11 » Sun Apr 06, 2025 12:29 am
KENSAI wrote: Sun Apr 06, 2025 12:19 am Am I reading your post correctly that there are no slimline enclosure options? Just the hulking 5.25" enclosures? They're so...BIG. :lol:
all slims with old fw are gone since summer of 2023 in the usa thats when i ran out of those
212 with owc case is very good to make a usb drive
oakiearkie
#1002 Post by oakiearkie » Mon Apr 07, 2025 3:29 am
Are there any tips/tricks to getting the Pioneer drives to fit in the OWC Mercury Pro case? Do you just have to drill new holes?
#1003 Post by Billycar11 » Mon Apr 07, 2025 6:09 am
oakiearkie wrote: Mon Apr 07, 2025 3:29 am Are there any tips/tricks to getting the Pioneer drives to fit in the OWC Mercury Pro case? Do you just have to drill new holes?
you can slot it with a Dremel or bend the tabs
i slotted mine with a Dremel
Avalanche1269
#1004 Post by Avalanche1269 » Wed Apr 09, 2025 12:11 am
Great seller, received item as advertised and Billy helped me out when I had questions. Would recommend.
mashwell
#1005 Post by mashwell » Wed Apr 09, 2025 5:56 pm
As others have attested, great seller with an excellent product. Got a 212 drive from Billy for a new AMD Windows build and everything went smoothly. Drive is up and running without any issues. I have used it for both regular and 4K Blu-ray MakeMKV rips.
