email sentBillycar11 wrote: ↑Mon Mar 31, 2025 7:59 pmsure email me for a flasherPtitvert wrote: ↑Mon Mar 31, 2025 7:56 pmHi everyone,
I've just got this drive:
Could you help me how to "flash" or "LibreDrive" it?Code: Select all
Drive Information Manufacturer: ASUS Product: BW-16D1X-U Revision: E113 Serial number: ... Firmware date: 2020-07-21 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID76
Thank you very much in advance for your help.
Asus BW-16D1X-U
Re: Asus BW-16D1X-U
Re: Asus BW-16D1X-U
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: D***********
Highest AACS version: 81
Hi, newbie here. First post. I notice this is very similar to previous ones. Is it OK to PM for details of flashing the drive? I'm on the latest Mac OS.
Thanks in advance.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Thanks in advance.
Re: Asus BW-16D1X-U
sure email me that info see belowtony.riviere wrote: ↑Thu Apr 03, 2025 10:09 amDrive Information
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Thanks in advance.
Re: Asus BW-16D1X-U
Just wanted to say "Thank you" to Billycar11Ptitvert wrote: ↑Mon Mar 31, 2025 8:08 pmemail sentBillycar11 wrote: ↑Mon Mar 31, 2025 7:59 pmsure email me for a flasherPtitvert wrote: ↑Mon Mar 31, 2025 7:56 pmHi everyone,
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number: ...
Drive platform: RS8F01
Firmware version: 1.01/ID72
Now just waiting for the latest version of makeMKV that works with the new macos 15.4
Re: Asus BW-16D1X-U
Hey All,
I'm not having any luck with this. Can anyone offer some guidance?
Here's my MakeMKV driver info:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: ...
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Highest AACS version: 75
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
It's a 2021 drive on a Mac (MacBook Air M2 chip, Sequoia 15.4) connected via USB-C
That's the drive info after I attempted to flash it with the Terminal.
xxxxx-MacBook-Air:MacOS mcclayton$ ./makemkvcon f -d /IOBDServices/F0D08170 -f /Users/xxxx/Desktop/sdf.bin rawflash enc -i /Users/xxxx/Desktop/ASUS-BW-16D1H-U-A204-WM01001-211901041044.bin
Reading input file /Users/xxxx/Desktop/ASUS-BW-16D1H-U-A204-WM01001-211901041044.bin
Current Drive ID: ASUS_BW-16D1X-U_A104_211901041047_KLZL4TE4954
yes
100% Operation finished
Done successfully
After flashing, I restarted both the drive and MakeMKV and there's no change in the drive info. Any pointers?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: ...
yes
Done successfully
Re: Asus BW-16D1X-U
Firmware is not encrypted so change enc to main.drwhotoo wrote: ↑Fri Apr 11, 2025 5:49 pmHey All,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: ...
yes
Done successfully
Re: Asus BW-16D1X-U
Damn! I can't believe that worked. Thanks so much!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A204
Serial number: ...
Firmware date: 2119-01-04 10:44
Firmware version: 0.A204W
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A204
Serial number: ...
Re: Asus BW-16D1X-U
Hi everyone, I got this drive second-hand, and I'm wondering if it's possible to be patched to enable 4k support. Can somebody point me in the right direction?
This is the drive info:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: ---
Firmware date: 2015-10-20
Highest AACS version: 63
Drive platform: RS8600
Firmware version: E101/ID76
Re: Asus BW-16D1X-U
PM sent.spiritofxxc wrote: ↑Mon Apr 21, 2025 1:40 amHi everyone, I got this drive second-hand, and I'm wondering if it's possible to be patched to enable 4k support. Can somebody point me in the right direction?
This is the drive info:Code: Select all
Drive Information Manufacturer: ASUS Product: BW-16D1X-U Revision: E101 Serial number: --- Firmware date: 2015-10-20 Bus encryption flags: 1B Highest AACS version: 63 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: E101/ID76 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Re: Asus BW-16D1X-U
Thanks a lot! It worked perfectly!Coopervid wrote: ↑Mon Apr 21, 2025 10:19 amPM sent.spiritofxxc wrote: ↑Mon Apr 21, 2025 1:40 amHi everyone, I got this drive second-hand, and I'm wondering if it's possible to be patched to enable 4k support. Can somebody point me in the right direction?
Re: Asus BW-16D1X-U
hello guys,I need some help to flash my drive
This is the drive:
This is the drive:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Drive platform: RS8F00
Firmware version: E116/ID71
Re: Asus BW-16D1X-U
PM sent.leifeng wrote: ↑Sun May 04, 2025 9:54 amhello guys,I need some help to flash my drive
This is the drive:Code: Select all
Drive Information OS device name: G: Manufacturer: ASUS Product: BW-16D1H-U Revision: E116 Serial number: Firmware date: 2020-07-21 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: E116/ID71 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Re: Asus BW-16D1X-U
thank you,it can work nowCoopervid wrote: ↑Sun May 04, 2025 8:47 pmPM sent.leifeng wrote: ↑Sun May 04, 2025 9:54 amhello guys,I need some help to flash my drive
Re: Asus BW-16D1X-U
Back when I bought my external drive, I was dissapointed to find out it was not UHD friendly, some even claimed it could not read UHD bc hardware was not present. Decided today to see if anything changed and am unsure if it has. Here's my drive info, still no UHD?
Also if it is possible, will I lose the capability to write 100GB M-Disks?
Thanks for your time!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number:
Firmware date: 2019-03-07
Firmware version: E115/ID71
Re: Asus BW-16D1X-U
PM sent. You will just add capabilities.MysticWizard wrote: ↑Sat May 10, 2025 2:12 pmBack when I bought my external drive, I was dissapointed to find out it was not UHD friendly, some even claimed it could not read UHD bc hardware was not present. Decided today to see if anything changed and am unsure if it has. Here's my drive info, still no UHD?
Drive Information OS device name: D: Manufacturer: ASUS Product: BW-16D1H-U Revision: E115 Serial number: Firmware date: 2019-03-07 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: E115/ID71 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
