BDR 212V UHD Guide
fzman1956
Re: BDR 212V UHD Guide
Post by fzman1956 »
Coopervid wrote:
Sun Mar 23, 2025 11:06 am
PM sent.
Message received Thanks!
Rudyard
Post by Rudyard »
Coopervid wrote:
Sun Mar 23, 2025 11:04 am
Rudyard wrote:
Sat Mar 22, 2025 12:44 am
Hello again. I've got a second Pioneer drive. At first I thought it was another BDR-212V, but alas, it happens to be a BDR-212DBK. Is there anything I can do to enable UHD on this one? Just in case, this is what MakeMKV says about the drive:
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.02
Serial number:
Firmware date: 2022-03-16
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8F00
Firmware version: 1.02/ID61
Thank you in advance.
PM sent.
Thank you. It worked :)
I've got a question, though. Does this firmware downgrade enable, by any chance, the ability to write BDXL media?
Rudyard wrote:
Wed Mar 26, 2025 8:39 am
Revision: 1.02
Serial number:
PM sent.
Yes, it does. However the DBK uses a plastic lens for the laser instead of a glass lens compared with the 212 drives that are BDXL enabled from the factory. So it is a little less precise regarding writing. But if you want to burn BDXL you should regardless use this method with spare areas anyway.
https://mega.nz/file/rFpkgKzT#KopvNzU5R ... DiHIoVA9T0
onkloud9
Post by onkloud9 »
Hey Coopervid, can I get some help with this?
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ,,,
Firmware date: 2022-05-31
Firmware version: ID06
onkloud9 wrote:
Sat Mar 29, 2025 11:40 pm
Revision: 1.02
Serial number: ,,,
PM sent.
Yethidran
Post by Yethidran »
Hi Coopervid,
just got myself a BDR-212V, but MakeMKV reports that its a BD-RW BDR-S12JX drive running on a BDR-212T Platform with RS8F01.
any chance to get the "Libre firmware" for this drive?
OS device name: E:
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number: BADL017858WL
Firmware date: 2020-07-21
Highest AACS version: 61
Drive platform: RS8F01
Firmware version: 1.01/ID72
Yethidran wrote:
Wed Apr 02, 2025 9:35 am
Hi Coopervid,
OS device name: E:
Revision: 1.01
it already is...
does it work its someone's return lol
Yethidran
Post by Yethidran »
i tried spinning up a 4k uhd disc in it, but it says no disc. then i tried a regular audio cd, and it played that audio cd.
then i opened the drive up to clean the len's but it still cant pick up the 4k uhd disc, only audio cd's it can play.
Yethidran wrote:
Wed Apr 02, 2025 10:52 am
You nee to try regular BDs, not audio discs. If that doesn't work the drive is defective. I also assume it's a return.
Yethidran
Post by Yethidran »
Thanks Coopervid, i have flashed it with success. firmware version went up to 1.02 (It was version 1.01 before), and the drive became a BDR-S12U (It was a BDR-S12JX before).
after flashing it, it struggled to read a 4k uhd disc, (lots of clicking noise internally) but it eventually played it and Makemkv was able to read it too.
but just to satisfy myself, i tried it a 2nd time, and this time it totally failed. no disc detected. even regular bluray disc couldnt show up, only regular audio cds were fine.
guess i got a "Borked Set"
but thanks anyway for the help buddy.
attached below are the "Before and After" flashing readouts.
OS device name: E:
Revision: 1.01
Serial number: ...
Product: BD-RW BDR-S12U
Revision: 1.02
Serial number: ...
Firmware date: 2022-03-07
Firmware version: 1.02/ID43
Yethidran
Post by Yethidran »
and i cant return it too, as i opened the chassis to clean the lens too. there was a warranty seal that i had to remove to gain access for cleaning the lens.
so one nice Pioneer down the drain for me.
Hehehehe!! oh well life goes on.....
Yethidran wrote:
Wed Apr 02, 2025 7:51 pm
Yeah, the blue laser is defective. It was a return.
razer
Post by razer »
Hello Coopervid,
I sent you a PM regarding activating a Pioneer 212V drive.
OS device name: F:
Revision: 1.02
Serial number: DGDXXXXXXXXX
Highest AACS version: 81
Thank you,
r.
