BD-RE PIONEER BD-RW BDR-UD04 1.11
Cuddy2977
Post by Cuddy2977 »
OK: I have a BD-RE PIONEER BD-RW BDR-UD04 reader/burner: that, up until now, has read 4k discs perfectly well
Except … ?
When I’ve tried copying the 4k disc in the recent Aliens box set, I get a lot of error message: either when trying to back the disc up, or trying to open it.
What IS happening … ?
(The disc spins as if it’s being read when I put it into the drive: and shows up on the desktop. Beyond that, I get errors.)
Re: BD-RE PIONEER BD-RW BDR-UD04 1.11
Cuddy2977 wrote: Wed Apr 02, 2025 5:24 pm OK: I have a BD-RE PIONEER BD-RW BDR-UD04 reader/burner: that, up until now, has read 4k discs perfectly well
Except … ?
Wash the disc with warm water and liquid soap.
Cuddy2977
Post by Cuddy2977 »
Coopervid wrote: Wed Apr 02, 2025 5:29 pm
Except … ?
Would that work? Should it be needed?
The disc is *literally* fresh out of the package.
Cuddy2977 wrote: Wed Apr 02, 2025 5:32 pm
Except … ?
Try it. New discs very often have a film on it that is invisible but makes them hard to read. I pretty much wash all UHD discs before I rip them.
Cuddy2977
Post by Cuddy2977 »
As an extra thought, and before I wash the thing in soapy water?
I’ve *just* tried backing the disc up, again: and, after a lot of ‘Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR’ warnings, been told ‘The volume key is unknown for this disc - video can’t be decrypted’
What the fornication is going on, and how do I stop it?
Cuddy2977
Post by Cuddy2977 »
Coopervid wrote: Wed Apr 02, 2025 5:35 pm
OK, Cheers, Coopervid.
I’ve tried that … and, when I put the blessed thing back in, it kept appearing and disappearing from the desktop!
And … ?
Now I’ve updated to Sequoia 15.4, there seems to be more problems!
I’m having a bad week!
Read this:
viewtopic.php?f=4&t=37090&start=75
Regarding unsupported discs: You should use KEYDB.cfg.
viewtopic.php?f=12&t=32784&p=148909&hil ... fg#p148909
