How to enable LibreDrive
sheldonxxxx
Post by sheldonxxxx » Wed Apr 02, 2025 3:21 pm
Hi, does 'possible' means I can flash a libredrive enabled firmware? If so, which firmware should i flash?
OS device name: /dev/rdisk6
Product: BD-RE BP71N
Revision: 1.03
Serial number: SIK09P31A5857
Firmware date: 2122-02-18 16:25
Bus encryption flags: 1F
Highest AACS version: 81
Re: How to enable LibreDrive
Post by Coopervid » Wed Apr 02, 2025 5:31 pm
sheldonxxxx wrote: Wed Apr 02, 2025 3:21 pm Hi, does 'possible' means I can flash a libredrive enabled firmware? If so, which firmware should i flash?
Revision: 1.03
Is this a full size or a slim drive?
zittrig
Post by zittrig » Wed Apr 02, 2025 5:41 pm
Check this out --> viewtopic.php?t=31005
LG BU40N 1.03MK should work.
