daffie
Post by daffie »
RESET_9999 wrote: Mon Mar 31, 2025 10:31 pm yes, you have to disable smooth gradation. This setting removes fine details anyway.
HDR10:
DoVi
Did the comparison again with smooth gradation off but it doesn't change anything. I hardly see any difference between the HDR10 sample files and the Dovi ones.
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
daffie wrote: Tue Apr 01, 2025 9:07 pm Did the comparison again with smooth gradation off but it doesn't change anything. I hardly see any difference between the HDR10 sample files and the Dovi ones.
Are you watching in a dark room?
Near black Posterization and banding on LG OLED TVs is a well-known issue, and many people have moved to QD-OLED Samsung because of that. My Samsung monitor and Hisense LED TV don't have any of those LG issues.
daffie
Post by daffie »
RESET_9999 wrote: Tue Apr 01, 2025 9:53 pm
Yes I'm watching in a dark room. The sun was down for hours and there were no lights.
Guess I still got a good one from LG :)
I would never move to Samsung by the way. A company that doesn't support Dolby Vision can't take my money.
except there is no exception to this lg issues, even the latest G5 has it..
you just don't see the problem
daffie
Post by daffie »
Glad I don't see the problem :D
deadchip12
Post by deadchip12 »
@RESET_9999
For Nosferatu (2024), if my cmv 2.9 bluray version is extended cut and your cmv 4.0 RPU is theatrical then they won't work together, right?
coopzr
Post by coopzr »
deadchip12 wrote: Thu Apr 10, 2025 3:14 am @RESET_9999
I'm not reset, but that's correct. It will work up until the first extra/added scene, and then everything will be out of sync thereafter.
daffie
Post by daffie »
RESET_9999 wrote: Wed Apr 02, 2025 10:34 am except there is no exception to this lg issues, even the latest G5 has it..
I actually didn't see the problem because the problem was not there for me at that time :-)
I had my TV calibrated yesterday and now in the calibrated picture I can clearly see the banding in ''The Martian'' sample in HDR10.
BUT this goes away for 90% by setting smooth gradation to LOW.
In Dolby Vision there is no banding - also with smooth gradation OFF.
Yeah, I'm hearing the same from the G5. It's a good thing we can generate DV for everything.
LV8HD
Post by LV8HD »
In the HDR10+ injection workflow the delay doesn't get applied.
Here are the original scene cuts:
"SceneInfoSummary": {
    "SceneFirstFrameIndex": [
      0,
      24,
      144,
      180,
      300,
      336,
      456,
      492,
      612,
      4213,
      4232,
      4514,
      4561,
      4669,
      4884,
      5120,
And here are the "synced" scene cuts:
      0,
      24,
      144,
      180,
      300,
      336,
      456,
      492,
      612,
      4213,
      4232,
      4514,
      4561,
      4669,
      4884,
      5120,
May it be a problem in the script that delays HDR10+ metadata?
I dont know, works fine for me when I check the new scene cuts in 2-1 and I get the framecount mismatch at injection..
Duplicating frame one, 24 times...
Warning: mismatched lengths. video 2876, HDR10+ JSON 2900
You have to check the injected/extracted json . This was the method used before hdr10plus_tool added native resync support. Hdr10plus tool recalculates the scene at injection.
If you get the latest beta and update hdr10plus_tool, you should be able to check sync directly with the edited json.
deadchip12
RESET_9999 wrote: Tue Apr 22, 2025 10:52 am Yeah, I'm hearing the same from the G5. It's a good thing we can generate DV for everything.
Not pc gaming though.
deadchip12 wrote: Wed Apr 23, 2025 4:39 pm Not pc gaming though.
Yeah, I don't play games. The HDR10 banding on my C2 isn't too distracting; I have to look pretty closely to notice it.
The posterization during fade-ins and fade-outs, on the other hand, looks really bad, and the uniformity isn't great either: I can see vertical bars in dark content.
Ordered the new 2500-nit LG 77'' G5 yesterday and should arrive on the 29th, so I'm hoping it performs better.
dom61
Post by dom61 »
RESET_9999 wrote: Wed Apr 23, 2025 4:52 pm ....
Hi Reset
Is the pedestal included or do you get the wall bracket?
I am also interested in the 77 but the pedestal I have to buy separately.
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
dom61 wrote: Wed Apr 23, 2025 4:56 pm
Hi Reset
I'm using this stand for my 77" C2, which is now going into my bedroom, so I ordered another one for the new TV.
https://www.amazon.ca/dp/B07ZYWXC56?ref ... title&th=1
