[BBC Earth - Life] Failed to open disc
Caesar
Post by Caesar » Wed Nov 24, 2010 6:33 pm
I've tried to open any of the four disc of this collection but MakeMKV always report the error "Failed to open disc"
Evaluation version, 29 day(s) out of 30 remaining
Title #00106.m2ts has length of 3517 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00107.m2ts has length of 3505 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00108.m2ts has length of 3526 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00109.mpls has length of 3517 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00110.mpls has length of 3505 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00111.mpls has length of 3526 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00116.mpls has length of 115 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00112.mpls has length of 3517 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00113.mpls has length of 3505 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00114.mpls has length of 3526 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00000.m2ts has length of 45 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00002.m2ts has length of 59 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00003.m2ts has length of 50 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00004.m2ts has length of 49 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00006.m2ts has length of 7 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00007.m2ts has length of 40 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00008.m2ts has length of 22 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00009.m2ts has length of 21 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00010.m2ts has length of 4 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00011.m2ts has length of 38 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00013.m2ts has length of 45 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00014.m2ts has length of 46 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00015.m2ts has length of 39 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00016.m2ts has length of 46 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00017.m2ts has length of 18 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00018.m2ts has length of 27 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00019.m2ts has length of 44 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00020.m2ts has length of 19 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00021.m2ts has length of 43 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00022.m2ts has length of 19 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00023.m2ts has length of 27 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00024.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00025.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00026.m2ts has length of 257 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00054.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00081.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00082.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00083.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00084.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00085.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00086.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00087.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00088.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00089.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00090.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00091.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00092.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00093.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00094.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00095.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00096.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00097.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00098.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00099.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00100.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00101.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00102.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00103.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00104.m2ts has length of 30 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00109.m2ts has length of 57 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00110.m2ts has length of 10 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00111.m2ts has length of 22 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00112.m2ts has length of 17 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
If I try to run from it from the CLI:
$ ./makemkvcon stream disc:1 --cache=128 --minlength=4800
MakeMKV v1.6.2 darwin(x86-release) started
Optical drive "DVD+R-DL _NEC DVD_RW ND-4570A 1.03" opened in OS access mode.
Optical drive "HD-DVD-ROM HL-DT-ST BD-RE  GGW-H20L YL03" opened in OS access mode.
Bus error
Any idea?
Caesar
Re: [BBC Earth - Life] Failed to open disc
Post by Caesar » Wed Nov 24, 2010 6:36 pm
Same problem with any disc of the twin collection "BBC Earth - Planet Earth".
Post by mike admin » Sat Nov 27, 2010 9:58 am
You have set minimum title length t0 4800 seconds and all titles on disc are shorter than this value.
Caesar
Post by Caesar » Thu Dec 08, 2011 3:59 pm
mike admin wrote:You have set minimum title length t0 4800 seconds and all titles on disc are shorter than this value.
I've recently updated makeMKV to the last version (v1.6.16, Mac build).
Now I'm able to open the disk:
MakeMKV v1.6.16 darwin(x86-release) started
Optical drive "DVD+R-DL _NEC DVD_RW ND-4570A 1.03" opened in DASPI v1.3 mode.
Optical drive "HD-DVD-ROM HL-DT-ST BD-RE GGW-H20L YL03" opened in DASPI v1.3 mode.
File 00106.m2ts was added as title #0
File 00107.m2ts was added as title #1
File 00108.m2ts was added as title #2
Title 00109.mpls is equal to title 00106.m2ts and was skipped
Title 00110.mpls is equal to title 00107.m2ts and was skipped
Title 00111.mpls is equal to title 00108.m2ts and was skipped
Title #00116.mpls has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00112.mpls is equal to title 00106.m2ts and was skipped
Title 00113.mpls is equal to title 00107.m2ts and was skipped
Title 00114.mpls is equal to title 00108.m2ts and was skipped
Title #00000.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00026.m2ts was added as title #3
Title #00054.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00092.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00094.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00095.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Streaming server started, web server address is http://127.0.0.1:51000 or http://localhost:51000
UPnP server enabled on address 127.0.0.1
When I try to stream it to VLC (1.1.12 64bit Mac build) i can only hear sound from the title playing without any video signal.
Since I don't know if it's a MakeMKV issues I'll post this on VLC forum too.
VLC is reporting no errors or warning; but in the message window it reports these messages...
avcodec warning: cannot decode one frame (192626 bytes)
avcodec warning: cannot decode one frame (8406 bytes)
avcodec warning: cannot decode one frame (9252 bytes)
avcodec warning: cannot decode one frame (47811 bytes)
avcodec warning: cannot decode one frame (344444 bytes)
avcodec warning: cannot decode one frame (7197 bytes)
avcodec warning: cannot decode one frame (7506 bytes)
avcodec warning: cannot decode one frame (234468 bytes)
avcodec warning: cannot decode one frame (9815 bytes)
avcodec warning: cannot decode one frame (9931 bytes)
avcodec warning: cannot decode one frame (202179 bytes)
avcodec warning: cannot decode one frame (8728 bytes)
avcodec warning: cannot decode one frame (9245 bytes)
avcodec warning: cannot decode one frame (202409 bytes)
avcodec warning: cannot decode one frame (8744 bytes)
avcodec warning: cannot decode one frame (9573 bytes)
avcodec warning: cannot decode one frame (205863 bytes)
avcodec warning: cannot decode one frame (8856 bytes)
avcodec warning: cannot decode one frame (9509 bytes)
avcodec warning: cannot decode one frame (208885 bytes)
avcodec warning: cannot decode one frame (9093 bytes)
Probably a VC-1 codec problem related to VLC...
Trying *.m2ts stream playback.
Screen shot 2011-12-08 at 16.54.03.png (62.9 KiB) Viewed 10001 times
Trying *.ts stream playback.
Screen shot 2011-12-08 at 16.54.22.png (62.61 KiB) Viewed 10001 times
