Unique Disc ID
phileeny
Unique Disc ID
#1 Post by phileeny » Sun Mar 23, 2025 10:42 am
When I rip a DVD (yes I still watch and buy DVDs) with DVDs I use backup to ISO, with Blu-ray or 4k I backup to folder first then MKV later, but with the loads of discs I have there is sometimes the same film or bonus disc in special editions boxsets etc. and when the disc is inserted its name may come up the same or slightly different, now I know discs have a unique disc ID.
Is there a way to get this ID using MakeMKV now or in the future so I can avoid ripping a duplicate discs, or is there a free way to read this ID?
Unraid media server (self confessed data hoarder)
Zidoo x9 player Updated to Dune HD Pro One 8K Plus
65" TV and 9:1 sound system
Re: Unique Disc ID
#2 Post by dcoke22 » Wed Mar 26, 2025 12:25 pm
I'm aware of the Media Identification Code on writeable media. I'm not aware of a guaranteed unique ID on commercial pressed discs.
Couldn't you use some filename conventions or folder structure to allow for multiple versions of a movie to exist on your filesystem?
For example:
Alien (1979) - [boxset Alien Triple Pack].iso
Aliens (1986) - Special Edition - [boxset Alien Triple Pack].iso
Alien 3 (1992) - [boxset Alien Triple Pack].iso
flojo
Re: Unique Disc ID
#3 Post by flojo » Wed Mar 26, 2025 1:28 pm
phileeny wrote: Sun Mar 23, 2025 10:42 am ... now I know discs have a unique disc ID.
No, they do not have to. In fact I remember commercial DVDs that were seemingly authored once and simply had the VOBs swapped out... same volume label, menus and everything else.
Choose a file or files that are always present on the disc and hash them. 7z is multi-platform and simple. With some basic scripting you can also use a few megabytes of video. If you can't script then just get the volume label (if any) and match the patterns '*_0.VOB' and '*.IFO'. You could match an actual VOB, but that might take a while since the bottleneck is the drive speed, not the CPU speed. But you could get the sizes of all files, that should sort of be unique.
# An example:
7z h -ba -scrcSHA256 *_0.VOB *.IFO
e16f1596201850fd4a63680b27f603cb64e67176159be3d8ed78a4403fdb1700             2  VTS_1_0.VOB
c1b95499648ff119fdf2fde5807cb7c3d2cd5fb92f76f4f03692aa41659d889d             9  someting.IFO
# get filename and sizes NOTE: the 9 and 2 are because I used actual dummy files (one 9 byte and two 2 bytes)
stat -c '%s %n' *
9 someting.IFO
2 VTS_1_0.VOB
2 VTS_1_1.VOB
christopher2222
Re: Unique Disc ID
#4 Post by christopher2222 » Thu Mar 27, 2025 9:21 am
I've had the odd time where the mkv just goes to something like title01.mkv or something. A couple of times I've lost a few titles without noticing they were being overwritten. Just have to be aware.
phileeny
Re: Unique Disc ID
#5 Post by phileeny » Tue Apr 01, 2025 5:34 am
Thanks for the info.
When I put a disc in to DVD Profiler to database my collection it gives me a disc ID "C42A5E66C78593DF [MARVEL_STUDIOS_GUARDIANS_3]"
Or Mars Attacks my first DVD ever purchased "9C68E31EA5ED2F0A" I don't know where this "hash" is generated.
Re: Unique Disc ID
#6 Post by dcoke22 » Tue Apr 01, 2025 1:20 pm
http://www.invelos.com/Forums.aspx?task=viewtopic&topicID=926221
It seems, according to that thread, that DVD Profiler depends on something in Windows to generate a disc ID for DVDs. That thread is mostly about how a version of Windows 10 apparently changed how that was calculated so the new version of Windows generated a different disc ID for the same disc.
Out of curiosity, why are you trying to get this 'disc ID' hash?
flojo
Re: Unique Disc ID
#7 Post by flojo » Tue Apr 01, 2025 5:05 pm
dcoke22 wrote: Tue Apr 01, 2025 1:20 pm http://www.invelos.com/Forums.aspx?task=viewtopic&topicID=926221
It seems that AnyDVD's decryption proxy (for CSS) was on when one hash was generated, then off when another hash was generated. To me it seems like you should hash whatever is on the filesystem (UDF in this case), unless there's something stopping that.
There's a post stating they're getting different hashes from different software, which is unsurprising.
http://www.invelos.com/Forums.aspx?task ... 5#M3447185
