[SOLVED] Submitted Dump for AACS v82 BluRay AVXD_27860
Just so you know^^
Re: Submitted Dump for AACS v82 BluRay AVXD_27860
Hmmm takes longer than usual, probably a lot of v82 Discs that got released recently. Funny thing is, i bought two brand new BluRay. One was using Version 7x and the other one 82. It seems like the maker has some influence over which AACS Key is used for encryption.
If you post your MKBv82 disc dump file here (either as an attachment or file host link) your disc will probably be supported by the public keydb in less than one hour.Vamp898 wrote: ↑Mon Mar 31, 2025 6:42 amHmmm takes longer than usual, probably a lot of v82 Discs that got released recently. Funny thing is, i bought two brand new BluRay. One was using Version 7x and the other one 82. It seems like the maker has some influence over which AACS Key is used for encryption.
Otherwise you will need to wait for the next MakeMKV update as I believe the native "hashed keys" are not used for AACS1.0 discs.
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Thats a bummer.
Well, uploaded it here too
Your disc has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
As an Linux user, i copied the file manually to .MakeMKV but it worked like a charm =) thank you so much!
I wrote a small script to automate the process, when anyone has any use of it, feel free
https://nextcloud.ikaros.space/s/3wDSnx ... ydb_update
- Contact:
They are not usually, but they can be. Specifically for v82 we've added all the discs we got dumps for.keydb_helper wrote: ↑Mon Mar 31, 2025 8:06 amI believe the native "hashed keys" are not used for AACS1.0 discs.
Re: [SOLVED] Submitted Dump for AACS v82 BluRay AVXD_27860
Here is an AACS Dump File for a more recent disc.
https://www.blu-ray.com/movies/Jawan-Blu-ray/383753/
