[SOLVED] Submitted Dump for AACS v82 BluRay AVXD_27860
Vamp898
Post by Vamp898 » Thu Mar 27, 2025 3:10 pm
Just so you know^^
Vamp898
Re: Submitted Dump for AACS v82 BluRay AVXD_27860
Post by Vamp898 » Mon Mar 31, 2025 6:42 am
Hmmm takes longer than usual, probably a lot of v82 Discs that got released recently. Funny thing is, i bought two brand new BluRay. One was using Version 7x and the other one 82. It seems like the maker has some influence over which AACS Key is used for encryption.
keydb_helper
Post by keydb_helper » Mon Mar 31, 2025 8:06 am
If you post your MKBv82 disc dump file here (either as an attachment or file host link) your disc will probably be supported by the public keydb in less than one hour.
Otherwise you will need to wait for the next MakeMKV update as I believe the native "hashed keys" are not used for AACS1.0 discs.
Vamp898
Post by Vamp898 » Tue Apr 01, 2025 6:17 am
Thats a bummer.
Well, uploaded it here too
keydb_helper
Post by keydb_helper » Tue Apr 01, 2025 6:22 am
Thats a bummer.
Your disc has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Vamp898
Post by Vamp898 » Tue Apr 01, 2025 12:46 pm
As an Linux user, i copied the file manually to .MakeMKV but it worked like a charm =) thank you so much!
Vamp898
Post by Vamp898 » Tue Apr 01, 2025 12:59 pm
I wrote a small script to automate the process, when anyone has any use of it, feel free
https://nextcloud.ikaros.space/s/3wDSnx ... ydb_update
Post by mike admin » Tue Apr 01, 2025 8:30 pm
They are not usually, but they can be. Specifically for v82 we've added all the discs we got dumps for.
JSA_123
Re: [SOLVED] Submitted Dump for AACS v82 BluRay AVXD_27860
Post by JSA_123 » Thu May 22, 2025 4:07 pm
Here is an AACS Dump File for a more recent disc.
https://www.blu-ray.com/movies/Jawan-Blu-ray/383753/
