#10831
Post
by RESET_9999 » Mon Mar 31, 2025 8:01 pm
staknhalo wrote: ↑Mon Mar 31, 2025 7:22 pm
Disagree with that - bitrate always makes the image look noticeably sharper to me (even just in motion without having to screenshot), because of the more data, especially along lines or walls and hair and grass and stuff like that - especially now compared to some ~15Mbps HDR10 vs ~24Mbps DV5 encodes for the same title some places will pump out
Once I start getting to ~30Mbps+ HEVC I start having to freeze frame and pixel peep myself to notice any encoding differences (mainly with self encodes from UHD there cause I've only seen Sony put out ~75Mbps UHD disc level stuff with Bravia Core)
I guess you didn't compare or encode enough content because I'd take a 15mb/s encode from MAX, Disney or netflix over a 24mbps iTunes encode any day...
Some Bravia Core high bitrate encode are of worse quality than lower bitrate bluray remuxes.
bitrate means nothing if the encoding settings are bad or denoised like Apple does.
#10832
Post
by RESET_9999 » Mon Mar 31, 2025 8:02 pm
daffie wrote: ↑Mon Mar 31, 2025 7:58 pm
So for ALL movies/TV shows from Apple/iTunes we should never download the DV Web files but prefer the HDR10 Web versions?
P8 HDR10 version yes. As long as the brightness matches.
daffie
#10833
Post
by daffie » Mon Mar 31, 2025 10:11 pm
Yes. Both files play like they should on my Ugoos on LG G1. Thanks.
LG OLED65G1RLA / Samsung HW-Q990D / Sony UBP-X800M2 / Ugoos AM6B+ (CE with CPM Build)
#10834
Post
by RESET_9999 » Mon Mar 31, 2025 10:17 pm
daffie wrote: ↑Mon Mar 31, 2025 10:11 pm
Lucky you !
Could you please also try the banding and black fade samples in HDR10 and DV, and see if you get the same as my C2?
viewtopic.php?p=171761#p171761
thanks
daffie
#10835
Post
by daffie » Mon Mar 31, 2025 10:28 pm
RESET_9999 wrote: ↑Mon Mar 31, 2025 10:17 pm
Lucky you !
thanks
Yes I did this also. But I didn't reply because I'm not seeing the same things. I don't see much (if any) difference in banding in these examples between hdr10 and dv.
I did see a small difference in the black fade examples though. But not horrible like you say.
I do have the setting "Smooth gradation" to low, maybe that makes a difference?
#10836
Post
by RESET_9999 » Mon Mar 31, 2025 10:31 pm
yes, you have to disable smooth gradation. This setting removes fine details anyway.
HDR10:
DoVi
daffie
#10837
Post
by daffie » Tue Apr 01, 2025 5:53 am
Will try it again with smooth gradation off when I'm back from work later tonight.
rosavanwinkle
#10838
Post
by rosavanwinkle » Tue Apr 01, 2025 4:24 pm
My god....i havent being on this page in a while....the scripter who made this first happen rocking hard i see....
im gonna need a update on whats being changed dam....
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
daffie
#10839
Post
by daffie » Tue Apr 01, 2025 9:07 pm
RESET_9999 wrote: ↑Mon Mar 31, 2025 10:31 pm
HDR10:
DoVi
Did the comparison again with smooth gradation off but it doesn't change anything. I hardly see any difference between the HDR10 sample files and the Dovi ones.
#10840
Post
by RESET_9999 » Tue Apr 01, 2025 9:53 pm
daffie wrote: ↑Tue Apr 01, 2025 9:07 pm
Are you watching in a dark room?
Near black Posterization and banding on LG OLED TVs is a well-known issue, and many people have moved to QD-OLED Samsung because of that. My Samsung monitor and Hisense LED TV don't have any of those LG issues.
daffie
#10841
Post
by daffie » Wed Apr 02, 2025 6:22 am
RESET_9999 wrote: ↑Tue Apr 01, 2025 9:53 pm
Yes I'm watching in a dark room. The sun was down for hours and there were no lights.
Guess I still got a good one from LG
I would never move to Samsung by the way. A company that doesn't support Dolby Vision can't take my money.
#10842
Post
by RESET_9999 » Wed Apr 02, 2025 10:34 am
except there is no exception to this lg issues, even the latest G5 has it..
you just don't see the problem
daffie
#10843
Post
by daffie » Wed Apr 02, 2025 11:27 am
Glad I don't see the problem
deadchip12
#10844
Post
by deadchip12 » Thu Apr 10, 2025 3:14 am
@RESET_9999
For Nosferatu (2024), if my cmv 2.9 bluray version is extended cut and your cmv 4.0 RPU is theatrical then they won't work together, right?
coopzr
#10845
Post
by coopzr » Thu Apr 10, 2025 4:13 am
deadchip12 wrote: ↑Thu Apr 10, 2025 3:14 am
@RESET_9999
I'm not reset, but that's correct. It will work up until the first extra/added scene, and then everything will be out of sync thereafter.
