ASUS BW-12D1S-U
highcollar
ASUS BW-12D1S-U
Post by highcollar »
Hi! I'm new here. Today I've bought my 1st BD Drive.
It is ASUS BW-12D1S-U. Is it possible to flash it for UHD BD?
I'm reading that user "Coopervid" maybe knows how! Is it right? Can you help me? Thank You very much.
OS device name: /dev/rdisk7
Current profile: CD-ROM
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E102
Serial number: ...
Firmware date: 2011-05-06
Bus encryption flags: 13
Highest AACS version: 68
Status: Possible, but very unlikely to happen
Drive platform: Pioneer RS1030
Firmware version: ID71
Re: ASUS BW-12D1S-U
highcollar wrote:
Mon Mar 31, 2025 7:45 pm
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E102
Serial number: ...
No.
highcollar
Re: ASUS BW-12D1S-U
Why not? It is not possible? Thank U
Re: ASUS BW-12D1S-U
Guessing that being built over 4 years before UHD was invented affects the compatibility...
PurpleHaze
Re: ASUS BW-12D1S-U
Post by PurpleHaze »
Does anybody know if the ASUS BW-12D1S-U, can rip normal 1080p blurays?
Because I have found one sold for 50euro.
Re: ASUS BW-12D1S-U
PurpleHaze wrote:
Sun Apr 27, 2025 3:52 pm
It should work but I wouldn't buy it. LG type drives are shortlived anyway.
PurpleHaze
Re: ASUS BW-12D1S-U
Coopervid wrote:
Sun Apr 27, 2025 8:34 pm
Thank you for your answer, so you think it is better to save more and buy something with pioneer for about 120euro?
I'm only saying it cause my budget is pretty tight right now and to me it sounded like a good deal. However I'm a complete novice when it comes to ripping.
