IOS 15.4 update and Make MKV
randysolares
Post by randysolares »
Just updated to IOS 15.4 and now MakeMKV has a Fatal Error Occurred and will not work. I've already uninstalled and reinstall nothing. Any help would be greatly appreciated
Re: IOS 15.4 update and Make MKV
In the Mac section, there are two separate threads on this. Have you looked at those? It seems Apple doesn't care that the update is broken...
randysolares
Woodstock wrote: Mon Mar 31, 2025 8:31 pm In the Mac section, there are two separate threads on this. Have you looked at those? It seems Apple doesn't care that the update is broken...
Thanks Woodstock just found it with your help.
natra
Post by natra »
randysolares wrote: Mon Mar 31, 2025 8:53 pm
How did you fix the issue?
randysolares
[/quote]
See topic here:viewtopic.php?f=4&t=37090
