sure send that info to my email belowleovbernardo wrote: Sun Mar 30, 2025 3:30 am Hi! I've read a lot on this and the other thread wrt the PIONEER BDR-XD05 drive, and apparently many users are having success in making it read 4k UHD discs. Here is the drive info of my unit. Could you please assist me as well? Thanks in advance!![]()
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: OKDL018697UC
Firmware date: 2017-06-22
Highest AACS version: 76
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
LibreDrive for Pioneer drives
Hi.
It seems when I updated my firmware [without checking here] the Pioneer firmware zotzed by LibreDrive support.
Product: BD-RW BDR-XD08U
Revision: 1.04
Serial number: CADL001733UC
Firmware date: 2024-10-09
Highest AACS version: 81
Drive platform: Pioneer RS9331
Firmware version: ID05
Can it be fixed/recovered?
Revision: 1.04
no sorry man its ruined for nowEdwardB wrote: Mon Mar 31, 2025 7:54 pm Hi.
Revision: 1.04
i still have some pioneers with old fw if you want one
Grenadier_45
PM received but I don't appear to have enough posts to have permission to reply to PMs! That worked well, and you should have received a donation. Thank you very much indeed for your help!Coopervid wrote: Fri Mar 28, 2025 7:49 pmCheck your PM.Grenadier_45 wrote: Thu Mar 27, 2025 6:35 pm I don't suppose UHD ripping can be enabled on this drive?
Drive Information OS device name: I: Manufacturer: PIONEER Product: BD-RW BDR-S12 Revision: 1.01 Serial number: AEDL002534WL Firmware date: 2020-07-21 Bus encryption flags: 1B Highest AACS version: 64 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.01/ID45 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
Stubborn5228
I may be failing at search here, but any luck with this drive?
OS device name: H:
Product: BD-RW BDR-211M
Revision: 1.53
Serial number: SADL005544WL
Firmware date: 2020-08-03
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8801
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID60
Did you try an UHD disc? It should work.Stubborn5228 wrote: Thu Apr 03, 2025 6:58 pm I may be failing at search here, but any luck with this drive?Code: Select all
Drive Information OS device name: H: Manufacturer: PIONEER Product: BD-RW BDR-211M Revision: 1.53 Serial number: SADL005544WL Firmware date: 2020-08-03 Bus encryption flags: 13 Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS8801 Firmware name: PIONEER BDR-211 Firmware type: Original (unpatched) Firmware version: 1.53/ID60 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Stubborn5228
I am testing it out now. In an abundance of caution I had done nothing other than booting up makemkv and seeing if I could read the drive from the GUI flasher.
Testing a disc now.
Will I want to flash at some point?
Testing a disc now.
No. If it reads UHDs you are just fine.Stubborn5228 wrote: Thu Apr 03, 2025 7:40 pm I am testing it out now. In an abundance of caution I had done nothing other than booting up makemkv and seeing if I could read the drive from the GUI flasher.
Testing a disc now.
Stubborn5228
Vundebar!
The first easy drive experience I've had haha.
And I presume the general guidance to avoid any firmware update. Do you know if that's a windows update risk?
No. Just never update your drive's firmware. You would ruin it.Stubborn5228 wrote: Thu Apr 03, 2025 8:29 pm Vundebar!
SandraDorset
Is it possible to update this one?
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-S13JX
Revision: 1.04
Serienummer: X
Firmware-Datum: 2022-12-12
Highest AACS version: 82
Firmware version: ID72
Disk-Informationen
Label: SPY x FAMILY CODE White
Zeitstempel: 2025-02-28 08:05:04
Schutz: AACS v82
Datenkapazität: 35.77 Gb
Disk-Typ: BD-ROM
Anzahl der Layer: 2
Kanal-Bitlänge: 74,5 nm (max. 25.0 GB pro Layer)
Produzent: PIONEER
Revision: 1.04
Serienummer: X
Disk-Informationen
Schutz: AACS v82
Disk-Typ: BD-ROM
Anzahl der Layer: 2
No. The firmware is too new. Must be pre 12/2022.SandraDorset wrote: Fri Apr 04, 2025 8:52 pm Is it possible to update this one?
Produzent: PIONEER
Revision: 1.04
Serienummer: X
Disk-Informationen
Schutz: AACS v82
Disk-Typ: BD-ROM
Anzahl der Layer: 2
Pioneer BDR-X13J-S with v1.03 firmware
MakeMKV display Libredrive - possible
How to enable it ?, downgrade possible to v1.02 ?
Thank you.
Thank you.
AirborneRadio
Good afternoon!
I was reading this thread and checked my BD drive.
Does someone have what i'd need to unlock UHD blu-ray support?
I'm in Canada
I'm in Canada
Thanks!Drive Information
OS device name: E:
Product: BD-RW BDR-UD03
Revision: 1.11
Serial number: SJDL272014WL
Firmware date: 2018-11-28
Drive platform: RS8511
Firmware version: 1.11
PM sent.AirborneRadio wrote: Sat Apr 05, 2025 7:16 pm Good afternoon!
I'm in Canada
OS device name: E:
Revision: 1.11
