LibreDrive for Pioneer drives
Post by Billycar11 » Sun Mar 30, 2025 3:58 am
leovbernardo wrote: Sun Mar 30, 2025 3:30 am Hi! I've read a lot on this and the other thread wrt the PIONEER BDR-XD05 drive, and apparently many users are having success in making it read 4k UHD discs. Here is the drive info of my unit. Could you please assist me as well? Thanks in advance! :D
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: OKDL018697UC
Firmware date: 2017-06-22
Highest AACS version: 76
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
sure send that info to my email below
EdwardB
Post by EdwardB » Mon Mar 31, 2025 7:54 pm
Hi.
It seems when I updated my firmware [without checking here] the Pioneer firmware zotzed by LibreDrive support.
Product: BD-RW BDR-XD08U
Revision: 1.04
Serial number: CADL001733UC
Firmware date: 2024-10-09
Highest AACS version: 81
Drive platform: Pioneer RS9331
Firmware version: ID05
Can it be fixed/recovered?
Post by Billycar11 » Mon Mar 31, 2025 7:58 pm
EdwardB wrote: Mon Mar 31, 2025 7:54 pm Hi.
Revision: 1.04
no sorry man its ruined for now
i still have some pioneers with old fw if you want one
Grenadier_45
Post by Grenadier_45 » Tue Apr 01, 2025 11:56 am
Coopervid wrote: Fri Mar 28, 2025 7:49 pm
Grenadier_45 wrote: Thu Mar 27, 2025 6:35 pm I don't suppose UHD ripping can be enabled on this drive?
OS device name: I:
Product: BD-RW BDR-S12
Revision: 1.01
Serial number: AEDL002534WL
Firmware date: 2020-07-21
Highest AACS version: 64
Drive platform: RS8F00
Firmware version: 1.01/ID45
Check your PM.
PM received but I don't appear to have enough posts to have permission to reply to PMs! That worked well, and you should have received a donation. Thank you very much indeed for your help!
Stubborn5228
Post by Stubborn5228 » Thu Apr 03, 2025 6:58 pm
I may be failing at search here, but any luck with this drive?
OS device name: H:
Product: BD-RW BDR-211M
Revision: 1.53
Serial number: SADL005544WL
Firmware date: 2020-08-03
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8801
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID60
Post by Coopervid » Thu Apr 03, 2025 7:24 pm
Stubborn5228 wrote: Thu Apr 03, 2025 6:58 pm I may be failing at search here, but any luck with this drive?
OS device name: H:
Revision: 1.53
Did you try an UHD disc? It should work.
Stubborn5228
Post by Stubborn5228 » Thu Apr 03, 2025 7:40 pm
I am testing it out now. In an abundance of caution I had done nothing other than booting up makemkv and seeing if I could read the drive from the GUI flasher.
Testing a disc now.
Will I want to flash at some point?
Post by Coopervid » Thu Apr 03, 2025 8:16 pm
Stubborn5228 wrote: Thu Apr 03, 2025 7:40 pm I am testing it out now. In an abundance of caution I had done nothing other than booting up makemkv and seeing if I could read the drive from the GUI flasher.
Testing a disc now.
No. If it reads UHDs you are just fine.
Stubborn5228
Post by Stubborn5228 » Thu Apr 03, 2025 8:29 pm
Vundebar!
The first easy drive experience I've had haha.
And I presume the general guidance to avoid any firmware update. Do you know if that's a windows update risk?
Post by Coopervid » Thu Apr 03, 2025 9:41 pm
Stubborn5228 wrote: Thu Apr 03, 2025 8:29 pm Vundebar!
No. Just never update your drive's firmware. You would ruin it.
SandraDorset
Post by SandraDorset » Fri Apr 04, 2025 8:52 pm
Is it possible to update this one?
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-S13JX
Revision: 1.04
Serienummer: X
Firmware-Datum: 2022-12-12
Highest AACS version: 82
Firmware version: ID72
Disk-Informationen
Label: SPY x FAMILY CODE White
Zeitstempel: 2025-02-28 08:05:04
Schutz: AACS v82
Datenkapazität: 35.77 Gb
Disk-Typ: BD-ROM
Anzahl der Layer: 2
Kanal-Bitlänge: 74,5 nm (max. 25.0 GB pro Layer)
Post by MartyMcNuts » Fri Apr 04, 2025 11:49 pm
SandraDorset wrote: Fri Apr 04, 2025 8:52 pm Is it possible to update this one?
Produzent: PIONEER
Revision: 1.04
Serienummer: X
Disk-Informationen
Schutz: AACS v82
Disk-Typ: BD-ROM
Anzahl der Layer: 2
No. The firmware is too new. Must be pre 12/2022.
PeterMac
Post by PeterMac » Sat Apr 05, 2025 6:08 pm
Pioneer BDR-X13J-S with v1.03 firmware
MakeMKV display Libredrive - possible
How to enable it ?, downgrade possible to v1.02 ?
Thank you.
AirborneRadio
Post by AirborneRadio » Sat Apr 05, 2025 7:16 pm
Good afternoon!
I was reading this thread and checked my BD drive.
Does someone have what i'd need to unlock UHD blu-ray support?
I'm in Canada
OS device name: E:
Product: BD-RW BDR-UD03
Revision: 1.11
Serial number: SJDL272014WL
Firmware date: 2018-11-28
Drive platform: RS8511
Firmware version: 1.11
Post by Coopervid » Sun Apr 06, 2025 9:28 am
AirborneRadio wrote: Sat Apr 05, 2025 7:16 pm Good afternoon!
I'm in Canada
OS device name: E:
Revision: 1.11
PM sent.
