I'm having issues with one of my drives. It's a Pioneer BDR-XD05 and won't read any discs. I have tried multiple blu rays and dvds but it still won't read anything. I don't even hear the discs spin and the laser try to read them. I have used both included cable, a micro b to usb A cable, and a micro b to usb-c cable. Nothing has worked so far. The drive will power on but won't read anything.
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number:
Firmware date: 2017-06-22
Highest AACS version: 81
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
Pioneer BDR-XD05 Won't Read Discs
Re: Pioneer BDR-XD05 Won't Read Discs
try cleaning the lasers
Shermin3656
How would I go about cleaning the lasers as I'm not sure how to do that since I haven't done that before?
zittrig
Clean the laser with q-tip and alcohol. Dry immediately with a lint-free soft cloth or a dry q-tip. Do it twice.
The BDR-XD05 is an USB drive, so you don't have to open the enclosure, the laser lenses you can find there like you can see in the attachment (another drive but a good example).
Shermin3656
Thank you for that information! I will give that a shot and report on how it goes.zittrig wrote: Mon Mar 31, 2025 6:19 am Clean the laser with q-tip and alcohol. Dry immediately with a lint-free soft cloth or a dry q-tip. Do it twice.
Shermin3656
I finally had a chance to try this but I still can't get the drive to read any disc. The discs don't even spin in the drive. The drive powers on but no disc will spin and nothing is being read. Is the drive just a dud?zittrig wrote: Mon Mar 31, 2025 6:19 am Clean the laser with q-tip and alcohol. Dry immediately with a lint-free soft cloth or a dry q-tip. Do it twice.
Sounds like it's dead.Shermin3656 wrote: Sat Apr 05, 2025 1:22 amI finally had a chance to try this but I still can't get the drive to read any disc. The discs don't even spin in the drive. The drive powers on but no disc will spin and nothing is being read. Is the drive just a dud?zittrig wrote: Mon Mar 31, 2025 6:19 am Clean the laser with q-tip and alcohol. Dry immediately with a lint-free soft cloth or a dry q-tip. Do it twice.
bryank
Hi all,
I suddenly started having issues with my Pioneer BD-RW BDR-XD05 external dvd reader/writer.
Probably something fatal, but I thought I would see if anyone has any experience with this specific issue.
Revision: 3.10
Serial number:
Disc Information
Data capacity: 45.27 Gb
Disc type: BD-ROM
Number of layers: 2
I doubt it has anything to do with it but I upgraded to V1.18.1 just before I tried to rip a disc.
MakeMKV v1.18.1 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW BDR-XD05 3.10 QHDL118355UC' at offset '1048576'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW BDR-XD05 3.10 QHDL118355UC' at offset '655360'
udf: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
Revision: 3.10
Serial number:
Disc Information
Disc type: BD-ROM
Number of layers: 2
