Pioneer BDR-208D - "No disk" for UHD
NFGuy123
Re: Pioneer BDR-208D - "No disk" for UHD
Post by NFGuy123 »
This is the info I get from MakeMKV with my Pioneer BDR-208D:
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-208D
Revision: 1.10
Serienummer: LJDL004084WL
Firmware-Datum: 2012-08-22
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 77
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID61
Keine Disk eingelegt
Could you please send me the info how I can patch my device to read UHD too?
NFGuy123 wrote: Mon Mar 31, 2025 6:13 am This is the info I get from MakeMKV with my Pioneer BDR-208D:
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.10
sure email me see below
calli
Post by calli »
Hello coopervid and all the others here, with best regards!
In the faraway Germany I have the problem that my Pioneer BDR-208D can read almost all BlueRays, but unfortunately it does not read those from a provider with classical music. All possible apps for Windows have been tested and they report no disc in the drive or incorrect BlueRay parameters. Do I need to flash the drive? How and With what?
Many thanks in advance,
Calli
bishy77
Post by bishy77 »
Greetings all from the UK,
I have Pioneer BDR-208D (manufactured in January 2013), this is the drive info from MakeMKV:
Manufacturer: PIONEER
Product: BD-RW BDR-208D
Revision: 1.10
Serial number: MADL042304WL
Firmware date: 2012-08-22
Bus encryption flags: 13
Can the firmware be updated to support ripping of UHDs (I assume so given the post above)?
Kind regards,
bishy77 wrote: Sun Jul 20, 2025 11:12 am Greetings all from the UK,
Revision: 1.10
Kind regards,
Sure email me that drive info see below
bishy77
Post by bishy77 »
Thanks, have responded by email.
MIDIman403
Post by MIDIman403 »
I have a Pioneer BDR-208D and the drive information is below. Would this drive be capable of being flashed for UHD?
Revision: 1.10
Serial number: [redacted]
Highest AACS version: 68
MIDIman403 wrote: Tue Dec 30, 2025 12:53 am I have a Pioneer BDR-208D and the drive information is below. Would this drive be capable of being flashed for UHD?
Revision: 1.10
PM sent.
dukeforest
Post by dukeforest »
Can my 208M also support UHD?
Product: BD-RW BDR-208M
Revision: 1.50
Serial number:
Firmware date: 2015-09-24
Firmware version: 1.50
dukeforest wrote: Sun Jan 11, 2026 4:06 am Can my 208M also support UHD?
Revision: 1.50
Serial number:
PM sent.
iGoLin
Post by iGoLin »
Hello everyone, I just found out this forum and before throwing out my drive for not being able to do UHD I wanted to see if someone can help me.
This i s my MakeMKV info:
OS device name: F:
Revision: 1.10
Serial number:
Thank you all.
iGoLin wrote: Mon Jan 12, 2026 4:37 pm Hello everyone, I just found out this forum and before throwing out my drive for not being able to do UHD I wanted to see if someone can help me.
OS device name: F:
Revision: 1.10
Serial number:
Thank you all.
It can do UHD send me that makemkv drive info section see below for email
