I can't decrypt AACS v82 Blu-ray Disc
sumaho
Post by sumaho »
I have attached the AACS dump file and also tested with another Blu-ray disc.
Other Blu-rays work fine, but this specific disc shows the AACS v82 error.
I have also tried with the latest version of MakeMKV, but the issue persists.
Please let me know if any additional tests are needed.
MKB_v82_スマホを落としただけなのに_-最終章-_ファイナルハッキングゲーム_Blu-ray豪華版_本編DISC_CCA6.tgz
(87.4 KiB) Downloaded 275 times
Re: I can't decrypt AACS v82 Blu-ray Disc
Did you submit the dump file to svq@makemkv.com for a key to be generated?
sumaho
Post by sumaho »
Woodstock wrote: Mon Mar 31, 2025 12:49 pm Did you submit the dump file to svq@makemkv.com for a key to be generated?
I have sent the .tgz file to svq@makemkv.com. Is there anything else I need to do?
