“Fatal Error Occured” with MacOS 15.4 Developer Beta 1
nicholfd
Re: “Fatal Error Occured” with MacOS 15.4 Developer Beta 1
Post by nicholfd »
lostinlodos wrote: Mon Mar 31, 2025 2:33 am As a developer myself; I have two thoughts.
First, this looks intentional beyond the obvious, I believe they are trying to get ahead of a firmware attack that is reported but not generally not yet covered and as far as I can tell not in the wild yet.
Second: this change has broken most but not all ‘rippers’. Without being completely obvious the one from CN and the one from MY both still work. (Neither hold a candle to the ability of mMKV).
So does Daemon Tools.
I sincerely doubt this is intentional to this type of software.
Every piece of software of this type, for macOS, definitely uses some open source libraries for cross platform support. Apple uses (and documents) a lot of open source libraries within macOS. I suspect that a common piece of open source software/library is being used by the apps of this type that are now broken, and that Apple has deprecated it or moved on to a different version that theses apps weren't prepared for..
Konten
Post by Konten »
LemonMeringueTy wrote: Sun Mar 16, 2025 7:35 pm
lovemyflicks wrote: Sun Mar 16, 2025 4:38 pm FYI: As a temporary get around, I'm running a Windows 11 Virtual machine using Parallels. Makemkv for Windows works fine in that environment. Just a few extra steps. Definitely prefer to run it native on the mac.
I've tried this as well, but I keep getting the occasional SCSI error, and 4K's will not read whatsoever.
Everything was fine in the MacOS version.
Has anyone been able to make it work for 4K's using Parallels?
ehemmete
Post by ehemmete »
Same problem continues with the official 15.4 release.
redrighthand
Post by redrighthand »
Hi all
Having this issue too. Ripped a DVD before installing 15.4 (released today) and it worked fine. Tried to rip another one after I updated my Mac and I am getting this issue. Panicked thinking I had broken my computer!
Luckily I have an old laptop kicking about that I can use to rip in the meantime but it's not ideal.
Hoping the devs can look into it soon.
randysolares
Post by randysolares »
Same issue here just upgraded to official 15.4 and now Make MKV has fatal error, working perfectly today before upgrade.
asr101
Post by asr101 »
The Dev really should have issued a fast update with a warning banner notifying the user of this problem. I suspect that this forum is going to get rather busy over the next few days.
CoffeeDrinker
Post by CoffeeDrinker »
I am also having this issue since the update from today. I actually need to use this software soon. I hope you can fix this ASAP
ds1972
Post by ds1972 »
It would be appreciated if the developer, who people have paid money to for this software, could at least issue a statement.
DavoBR
Post by DavoBR »
Has anyone who has updated to 15.4, I'm still on 15.3.2, tried running MakeMKV in Parallels?
Post by mike admin »
The updated version for 15.4 will be available in a couple days.
DavoBR
Post by DavoBR »
mike admin wrote: Tue Apr 01, 2025 8:29 am The updated version for 15.4 will be available in a couple days.
Thanks Mike :D
Konten
Post by Konten »
Thanks, Mike!! So good to see you back on the forum... We missed you!! :D
jarodharris
Post by jarodharris »
Thanks Mike. Delighted to hear this!!!
madacj
Post by madacj »
That’s great news I’ve just encountered this problem myself but not on the beta macOS the finished version that was released last night sequoia 15.4
mm8718
Post by mm8718 »
Late to the party but seeing the same issue on official 15.4 update - thanks @mike !
