Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
Re: Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
2 ubks in stock now
use links proved in emails to purchase.
All gone
All gone
Jake-E
Forgot to update, my drive shipped fast and was packaged box in a box.
The Pioneer made short work of the 3 UHDs that my libredrive flashed LG didn't like: John Wick 4, They Live, The Thing.
Thanks Billycar11.
Thanks Billycar11.
FoxWing59
Wanted to say thanks to Billy for providing the Pioneer drives. I've bought some over the past year and they've all been great, none have had an issue at all with any of my discs.
ForTheFallen
Still have the 2 s13ubk’s in stock?Billycar11 wrote: Mon Mar 31, 2025 1:46 am 2 ubks in stock now
skelt11
I received my drive from Billy today. Supper fast response to my emails and fast shipping. I mounted the drive up in the OWC case (mounting bracket trick worked great), and it worked perfectly on my first go. Now I need more to speed things up.
PeterMac
Billycar11 - do you shipping to Poland ?
Have a question about BDR-213, which is latest firmware from Pioneer which work with MakeMKV to rip UHD BD ?
Sorry no I'm USA only asmcom has Europe coveredPeterMac wrote: Thu Apr 03, 2025 12:34 pm Billycar11 - do you shipping to Poland ?
PeterMac
Too bad
, maybe czary2mary will have something
Question about crossflashed Pioneer drives let's say BDR-212EBK to S12J-X to be MakeMKV Libredrive supported.
Does that drive crossflashed are same and 100% compatible with play UHD BD discs with PowerDVD ? or it's not same as real S12J-X ?
Since Intel deprecated SGX in their CPUs, Cyberlink has removed the ability to play UHDs in PowerDVD 22 and later. If you have a version that currently still works, it isn't a real long term solution.PeterMac wrote: Thu Apr 03, 2025 7:38 pm Too bad, maybe czary2mary will have something
KENSAI
Am I reading your post correctly that there are no slimline enclosure options? Just the hulking 5.25" enclosures? They're so...BIG.
all slims with old fw are gone since summer of 2023 in the usa thats when i ran out of thoseKENSAI wrote: Sun Apr 06, 2025 12:19 am Am I reading your post correctly that there are no slimline enclosure options? Just the hulking 5.25" enclosures? They're so...BIG.![]()
212 with owc case is very good to make a usb drive
oakiearkie
Are there any tips/tricks to getting the Pioneer drives to fit in the OWC Mercury Pro case? Do you just have to drill new holes?
you can slot it with a Dremel or bend the tabsoakiearkie wrote: Mon Apr 07, 2025 3:29 am Are there any tips/tricks to getting the Pioneer drives to fit in the OWC Mercury Pro case? Do you just have to drill new holes?
i slotted mine with a Dremel
Avalanche1269
Great seller, received item as advertised and Billy helped me out when I had questions. Would recommend.
mashwell
As others have attested, great seller with an excellent product. Got a 212 drive from Billy for a new AMD Windows build and everything went smoothly. Drive is up and running without any issues. I have used it for both regular and 4K Blu-ray MakeMKV rips.
