mhunt407
Posts: 5 Joined: Thu Mar 27, 2025 1:40 pm
Post
by mhunt407 » Fri Mar 28, 2025 10:13 pm
Apologies for the cross post if it's not the done thing, also have the same drive and didn't realise I couldn't read UHD. Coopervid, please would you able to help?
Thanks in advance!
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Mootunootu
Posts: 1 Joined: Sat Mar 29, 2025 4:55 am
Post
by Mootunootu » Sat Mar 29, 2025 4:57 am
Dear cooper vid, can you help me with playing UHD discs?
rec0n79
Posts: 1 Joined: Wed Oct 02, 2024 12:12 pm
Post
by rec0n79 » Sat Mar 29, 2025 5:53 pm
Hi Coopervid,
I see you are the man to talk to about the Verbatim 43890 firmware flash from UD03 to UD04
Here is the drive info...
OS device name: G:
Revision: 1.14
Serial number: ...
Any help would be great.
Stellavision
Posts: 9 Joined: Thu Mar 27, 2025 6:03 pm
Post
by Stellavision » Sat Mar 29, 2025 6:25 pm
So it looks like I messed up.
I sent back the Verbatim 43889 after reading on the manufacturers webstie that the 43888 is 4K capable out of the box and ordered that one instead.
However, after receiving the new one today I can confirm that the internals has annoyingly changed from the Pioneer BU04 to the LG BU40N. Subsequently this drive also needs flashing.
I have the files to flash this drive which I have taken from the relevent page on this forum, but I may take the advice of others on the forum and re purchase the 43889 with the better Pioneer internals.
Thank you in particular to Coopervid for the info you have provided to me.
To anyone else who reads this, if you have a choice between these drives, do not make the same mistake as me!
Posts: 4551 Joined: Tue Feb 19, 2019 10:32 pm
Post
by Coopervid » Sat Mar 29, 2025 9:55 pm
mhunt407 wrote: Fri Mar 28, 2025 10:13 pm
Thanks in advance!
Revision: 1.14
Serial number: ...
PM sent.
Post
by Coopervid » Sat Mar 29, 2025 10:01 pm
Mootunootu wrote: Sat Mar 29, 2025 4:57 am
Post your Makemkv info.
Post
by Coopervid » Sat Mar 29, 2025 10:02 pm
rec0n79 wrote: Sat Mar 29, 2025 5:53 pm
Hi Coopervid,
OS device name: G:
Revision: 1.14
Serial number: ...
PM sent.
mhunt407
Post
by mhunt407 » Sun Mar 30, 2025 11:08 am
Coopervid wrote: Sat Mar 29, 2025 9:55 pm
Thanks in advance!
Revision: 1.14
Serial number: ...
PM sent.
Thanks so much, worked perfect.
Lancery
Posts: 5 Joined: Sun Mar 30, 2025 8:34 pm
Post
by Lancery » Wed Apr 02, 2025 6:57 am
I am in the same boat. Is it possible for this drive to be able to support UHD? Can someone please help? TIA.
OS device name: F:
Current profile: DVD-ROM
Revision: 1.14
Serial number: ...
Highest AACS version: 12
tivo74
Posts: 1 Joined: Mon Mar 31, 2025 9:06 pm
Post
by tivo74 » Wed Apr 02, 2025 4:07 pm
Coopervid - would love your help as well, I just got mine, info below. Hoping to get your help flashing to BDR-UD04 functionality. Thanks!
Revision: 1.14
Serial number: ...
hollish
Posts: 2 Joined: Wed Apr 02, 2025 7:39 pm
Post
by hollish » Wed Apr 02, 2025 7:46 pm
Hi there @Coopervid, I feel bad joining in on the "please PM me firmware" band wagon, but I foolishly bought a 43890 thinking I could use it for UHD blu-rays, not really understanding the distinction as this is my first foray into backing up disc content. I was hoping to find a resolution on my own, but so far the only solution I have is "buy a different drive." I see you've still been helping people recently, so I hope you can find time to send me a PM as well.
Here is my Makemkv info:
OS device name: E:
Revision: 1.14
Serial number: ...
Thanks in advance!
Post
by Coopervid » Fri Apr 04, 2025 10:05 am
hollish wrote: Wed Apr 02, 2025 7:46 pm
OS device name: E:
Revision: 1.14
Serial number: ...
Thanks in advance!
PM sent.
hollish
Post
by hollish » Fri Apr 04, 2025 5:26 pm
Coopervid wrote: Fri Apr 04, 2025 10:05 am
PM sent.
Received, the flashing process was super easy. Many thanks!
conmitch
Posts: 1 Joined: Fri Apr 04, 2025 9:17 pm
Post
by conmitch » Fri Apr 04, 2025 9:22 pm
Dear Coopervid
Any chance i too could receive the firmware update for the 43890.
Much appreciated and thank you.
OS device name: H:
Revision: 1.14
Highest AACS version: 31
Post
by Coopervid » Sat Apr 05, 2025 9:32 am
conmitch wrote: Fri Apr 04, 2025 9:22 pm
Dear Coopervid
OS device name: H:
Revision: 1.14
PM sent.
