LG Slim Portable UHD BP60NB10
obitwan7
Post by obitwan7 »
I bought this a long time ago and I thought I gave it away, but was sitting in my basement collecting dust. It works just fine, but since I am ripping UHD's, I figured maybe this can work possibly if flashed right. I have no clue on flashing, but....would love to ask if anyone knows if this can be. Anyting would be appreciated. Here is the info I got from MakeMKV info:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: ...
Firmware date: 2120-05-07 09:35
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Re: LG Slim Portable UHD BP60NB10
Yes, it can be flashed. You can find instructions, tools, and firmware in the Ultimate UHD Drives Flashing Guide
obitwan7
Post by obitwan7 »
The only thing I found concerning my drive is: BP60NB10 on any Firmware directly to > BP60NB10 1.02MK
I have firmware 1.02 currently. Does this just change it to 1.02MK and it becomes enabled to rip the UHD discs? The link above to download says it's Hybrid_Firmware_for_BP50NB40_to_BP60NB10. Not with just my BP60NB10. So not sure or understand it. Any suggestions would be helpful. Thanks.
obitwan7 wrote:
Sat Mar 29, 2025 12:31 am
That hybrid stuff is not relevant to yuor drive. Just flash it with BP60NB10 1.02-MK firmware then libredrive and UHD readability will be enabled.
