#1261
Post
by MartyMcNuts » Mon Mar 17, 2025 10:20 pm
1zestytogepi wrote: Mon Mar 17, 2025 2:51 pm
hello ive got a wp50nb40 i want to flash it, i see that i need to flash it first to WH16NS60 1.02-MK, but im not sure where to locate that firmware to flash it to. Any help would be appreciated.
No, do not flash desktop firmware to a slim drive!!!
Follow the guide for BP50NB40 in the first post of this very thread. There's even a gif showing you what to do!
** NEW Single Drive Flasher ** available worldwide!
https://payhip.com/b/MyeJ9
Wiggles3443
#1262
Post
by Wiggles3443 » Sun Mar 23, 2025 2:15 pm
Apologies if this is somewhere in all of the comments, but I did not read through all of them and some searches that I did, didn't come back with anything.
I just got an LG drive, and noticed in MakeMKV it shows this information:
Product: BD-RE WH14NS40
Revision: 1.05
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.05
I was looking to update the firmware based on the info shown in LibreDrive information, and did some searching online to find the firmware and happened upon a reddit thread with very little information that referenced this thread here. I wanted to just understand if I should be looking to use this tool or not. I don't currently do anything with 4K/UHD discs, just bluray (for now that is). Things work mostly ok, but I run into some issues with discs both on my new LG drive as well as my older Pioneer drive (mainly read errors, but have started to see timeout errors and other errors recently with the LG drive that I never saw with the Pioneer drive). Is this tool something that could possibly help out with that or should I just look for the standard firmware update online and apply that? I'm not completely new to this whole software, but after reading through some different threads I'm finding that there is a ton I do not know about it and there are some very helpful and knowledgeable people out there. Just looking to see if this is mainly for those working with 4K/UHD discs or if it's something that everyone should be using (including me) to apply updates.
Thanks in advance to anyone who reads/replies/helps out. I do greatly appreciate it and your time!
#1263
Post
by d00zah » Sun Mar 23, 2025 2:37 pm
Wiggles3443 wrote: Sun Mar 23, 2025 2:15 pm
Revision: 1.05
FW won't necessarily help w/ read errors. 1st suggestion is always to clean a problem disc with a lint free cloth. Warm water & a dab of dish soap may be necessary for some. Even those fresh out of packaging are not exempt from this advice, even if they look perfect to the eye.
Pioneer drives are regarded as more reliable, overall, but
may not be LibreDrive capable.
The
Ultimate UHD Drives Flashing Guide Updated 2025 recommends:
(HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin)
Firmware version: 1.05 is encrypted, but this flash tool will handle it.
Wiggles3443
#1264
Post
by Wiggles3443 » Sun Mar 23, 2025 5:18 pm
d00zah wrote: Sun Mar 23, 2025 2:37 pm
The
Appreciate the response. So this won't help with read errors - that makes sense and I assumed it wouldn't. But flashing the drive basically makes it work with UHD discs correct? Looks like possibly opens up LibreDrive on the drive? Does that provide any benefits if only doing standard bluray discs and not trying to work with UHD discs?
Wiggles3443
#1265
Post
by Wiggles3443 » Sun Mar 23, 2025 5:29 pm
FWIW This is my Pioneer drive that I'm giving a go with some that had read issues with the LG drive.
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Firmware date: 2018-05-08
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.51/ID61
#1266
Post
by d00zah » Mon Mar 24, 2025 12:28 am
Wiggles3443 wrote: Sun Mar 23, 2025 5:18 pm
If the drive hardware is capable of UHD, LibreDrive makes then ripping possible. With less capable, but otherwise supported drives, see:
What is LibreDrive?
AACS host revocation, etc..
calorimetro
#1267
Post
by calorimetro » Tue Mar 25, 2025 9:23 pm
Hi, I flashed the firmware DE_LG_BH16NS55_1.02.bin (found on all you need package) on my drive BH16NS55 with the version 1.3.5 of software.
Then I tried to dump the firmware of the drive and I noticed the dump is different from the file I flashed.
Is it normal or something went wrong?
#1268
Post
by dcoke22 » Wed Mar 26, 2025 12:33 pm
calorimetro wrote: Tue Mar 25, 2025 9:23 pm
I think doing a firmware dump only gets the calibration data for the drive, not the whole firmware.
bloomstream
#1269
Post
by bloomstream » Fri Mar 28, 2025 4:05 am
Hi There,
I'm having issues with the SDFtool Flasher. There's an error that pops up when I click start.
Is it because my hardware's firmware isn't the same as the one on the pack? how can I fix this? I appreciate your help
#1270
Post
by MartyMcNuts » Fri Mar 28, 2025 10:29 pm
bloomstream wrote: Fri Mar 28, 2025 4:05 am
Hi There,
Ensure MakeMKV is installed in the default location.
Ensure thee is no disc in the drive and the tray is closed.
How is the drive connected to your Windows PC?
plantboy
#1271
Post
by plantboy » Sat Mar 29, 2025 12:23 am
MODEL: BH16NS40
SVC CODE: NS50
ROM VER: 1.04
Manufactured: June 2019
See attached photos. I've spent a few hours reading the information here, but I'm hung up on "WH16" vs. "BH16", unsure if any of the firmware packs have what I need.
I'd really appreciate guidance.
I've already made a firmware backup via the SDFtool Flasher.exe, and the backup was named like this:
dump_user_HL-DT-ST_BD-RE__BH16NS40_1.04_211901041338_KLKJ6PB3313.tar
- MakeMKV_Info.png (41.98 KiB) Viewed 27516 times
- DriveLabel.jpg (3.05 MiB) Viewed 27516 times
#1272
Post
by d00zah » Sat Mar 29, 2025 12:26 am
plantboy wrote: Sat Mar 29, 2025 12:23 am
MODEL: BH16NS40
SVC CODE: NS50
ROM VER: 1.04
Same hardware. "WH16" vs. "BH16" denotes OEM vs retail (or vice versa?).
#1273
Post
by MartyMcNuts » Sat Mar 29, 2025 4:16 am
MODEL: BH16NS40
SVC CODE: NS50
ROM VER: 1.04
That backup is only the important cal data. It's not a full firmware backup.
The recommended firmware for your drive is WH16NS60 1.02-MK.
Kenny42202
#1274
Post
by Kenny42202 » Sat Mar 29, 2025 8:29 pm
Am I able to use this drive for UHD ripping? Does everything look all good? Just got this drive today.
Mr_Orange
#1275
Post
by Mr_Orange » Sat Mar 29, 2025 10:06 pm
Kenny42202 wrote: Sat Mar 29, 2025 8:29 pm
Yes, the guide says:
Asus BW-16D1HT on any Firmware directly to > Asus BW-16D1HT 3.10MK
