Submitted Dump for Brimstone & Treacle UHD
buffalobossie
Post by buffalobossie »
Submitted by email a few days ago, but posting here as well in case it might find itself in a db of keys in the meantime.
Last edited by buffalobossie on Thu Apr 03, 2025 10:23 pm, edited 1 time in total.
Re: Submitted Dump for Brimstone & Treacle UHD
Post by SamuriHL »
0x2CA7CE328FF9A46525BCFAD5EF26ECFC972564CF
And incomplete entry for your disc exists in the keydb.cfg file. It won't work with MakeMKV because it lacks a VUK but if you use something like XReveal on Windows, you'd be able to open your disc and process it with MakeMKV. Either that or someone may come around and add a more complete entry to the keydb.cfg which will work with MakeMKV at some point.
keydb_helper
Post by keydb_helper »
buffalobossie wrote:
Thu Mar 27, 2025 8:11 pm
The 882A variant of Brimstone & Treacle now has a full record in the public keydb.
Emailing disc dumps to the MakeMKV team is always recommended but posting the disc dump file to the forum will generally result in same-day public keydb support.
Public KeyDB Disc Submissions
