MacOS 15.4 RC1 breaks Makemkv
Gilbert99
#1 Post by Gilbert99 » Tue Mar 25, 2025 1:44 pm
Fatal error popup when launched. App launches, but does not recognize disks.
Screenshot 2025-03-25 at 8.55.40 AM.png (161.48 KiB) Viewed 21461 times
Re: MacOS 15.4 RC1 breaks Makemkv
#2 Post by Woodstock » Tue Mar 25, 2025 1:48 pm
There is already an existing thread on the broken MacOS problems.
DavoBR
#3 Post by DavoBR » Tue Mar 25, 2025 1:52 pm
Gilbert99
#4 Post by Gilbert99 » Tue Mar 25, 2025 9:17 pm
Thanks. My workaround is to use Makemkv under Win 11 for ARM on Parallels. Seems to work so far
DavoBR
#5 Post by DavoBR » Wed Mar 26, 2025 8:40 am
Gilbert99 wrote: Tue Mar 25, 2025 9:17 pm Thanks. My workaround is to use Makemkv under Win 11 for ARM on Parallels. Seems to work so far
That could be my future workaround. Meanwhile, I'm sticking with 15.3.2 and not going near any MacOS Beta/RC.
Gilbert99
#6 Post by Gilbert99 » Thu Mar 27, 2025 4:53 pm
Feedback Assistant response from Apple states Change required from3'rd party
