[SOLVED] Submitted Dump for AACS v82 BluRay AVXD_27860
Just so you know^^
Re: Submitted Dump for AACS v82 BluRay AVXD_27860
Hmmm takes longer than usual, probably a lot of v82 Discs that got released recently. Funny thing is, i bought two brand new BluRay. One was using Version 7x and the other one 82. It seems like the maker has some influence over which AACS Key is used for encryption.
keydb_helper
If you post your MKBv82 disc dump file here (either as an attachment or file host link) your disc will probably be supported by the public keydb in less than one hour.Vamp898 wrote: Mon Mar 31, 2025 6:42 am Hmmm takes longer than usual, probably a lot of v82 Discs that got released recently. Funny thing is, i bought two brand new BluRay. One was using Version 7x and the other one 82. It seems like the maker has some influence over which AACS Key is used for encryption.
Otherwise you will need to wait for the next MakeMKV update as I believe the native "hashed keys" are not used for AACS1.0 discs.
Public KeyDB Disc Submissions
Thats a bummer.
Well, uploaded it here too
keydb_helper
Your disc has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
As an Linux user, i copied the file manually to .MakeMKV but it worked like a charm =) thank you so much!
I wrote a small script to automate the process, when anyone has any use of it, feel free
https://nextcloud.ikaros.space/s/3wDSnx ... ydb_update
- Contact:
They are not usually, but they can be. Specifically for v82 we've added all the discs we got dumps for.keydb_helper wrote: Mon Mar 31, 2025 8:06 am I believe the native "hashed keys" are not used for AACS1.0 discs.
