[SOLVED] AACS v82 Discs HELP!
ChemKing
Post by ChemKing »
Hi everyone,
I'm currently facing an issue with decrypting some Discs that are protected with AACS v82. From what I've gathered in the forum, it seems that the current version of MakeMKV doesn’t support v82 yet, and we may need to wait for an update. However, I’ve also seen that some users can update the key database manually to enable decryption.
I’m reaching out to ask for help—would anyone be able to update the key database? Do I need to provide any files? From what I understand, I should share the dumped .tgz files. I’ve attached them below. (Five Discs info in a Zip file.) If any other files are required, please let me know.
Once the keys are added to the database, I should be able to download and unzip the keydb.cfg file from http://fvonline-db.bplaced.net/ and use it with MakeMKV to decrypt the discs, correct?
Thanks in advance for your help! I really appreciate it.
MKB_v82_NSBX_54429.zip
(468.12 KiB) Downloaded 605 times
ChemKing
Re: AACS v82 Discs HELP!
Post by ChemKing »
Here are dumped info
(468.12 KiB) Downloaded 712 times
ChemKing
Post by ChemKing »
Thanks, guys!
Keys exist in the newest keydb.cfg! :D
