I recently got what was announced to be a Pioneer BDR-212DBK drive. I was told this doesn't work for UHD discs, so updating the FW makes no difference.
What I was wondering is this:
1) Based on the MAKEMKV info (that I got after reading it for the 1st time today), is this really the Pioneer BDR-212DBK? This is what the drive itself says, but I got without a case/box, so I need to confirm either way. Contrary to Apple products, I don't think there's a website that checks serial numbers to confirm what kind of product is.
Informações da Unidade
Nome do dispositivo do SO: E:
Fabricante: PIONEER
Produto: BD-RW BDR-212D
Revisão: 1.00
Número de série: AEDL034750WL
Data do Firmware: 2019-01-10
Sinalizações de criptografia bus: 13
Drive platform: RS8F00
Firmware version: 1.00/ID61
2) Assuming it is:
- Apparently two firmware updates were released for it:
https://pioneer.jp/device_e/product-e/i ... BDR-212DBK
BDR-212DBK
ver. change point
1.03 Improvement of the playback operation with specific media
1.02 Improvement of the playback operation with specific media
1.01 Improvement of the operational stability when BD-R SL 16x speed recording.
Improvement of the operational stability when recording CD, DVD, BD.
Pioneer's website says:
https://pioneer.jp/device_e/product-e/i ... 01r_e.html
BDR-212DBK_FW103EU.exe
(2.66 MB)
updated Dec 21, 2022
BD/DVD/CD Drive
Once updated to version 1.03, this drive will not revert to older firmware versions.
Is this the firmware I should download and apply to it? I am asking this because there's always a "but" when we pick an european firmware (at least for routers?) when the product is from USA/America. In this case, if it's really this one I need, I assume it's for all BDR-212DBK regardless of where they were purchased.
3) I plan to use this drive to play region 4/NTSC (DVDs) from Brazil. Regular Blu-rays with region "A" are from Brazil and United States. Besides the fact only 5 changes are possible (and if I need to put a R1 disc, I'll rip it), I was told in the past when we buy a NEW drive, we always need to set a region code.
Apparently when the drive is brand new, there is no region code set. I believe at least for the now defunct AnyDVD (?) this was not a good idea, we needed to set one (4 and "A" in my case) for the ripping tool to work properly.
Help with the BDR-212DBK drive (FW and region-code)
Re: Help with the BDR-212DBK drive (FW and region-code)
DO NOT UPDATE this firmware. Your drive can be flashed for reading UHDs but not anymore when you update it. As soon as I'm back you will receive a PM.Swazirs wrote: ↑Thu Mar 13, 2025 3:58 pmHello,
Fabricante: PIONEER
Revisão: 1.00
2) Assuming it is:
BDR-212DBK
ver. change point
(2.66 MB)
BD/DVD/CD Drive
BlackBerryBrad
I recently purchased this drive and was wondering if I could get help with flashing. Can this drive be flashed? Any help is greatly appreciated!
OS device name: J:
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: ...
Firmware date: 2022-03-16
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: 1.02/ID61
OS device name: J:
Revision: 1.02
Serial number: ...
PM sent.BlackBerryBrad wrote: ↑Tue Mar 25, 2025 5:31 pmI recently purchased this drive and was wondering if I could get help with flashing. Can this drive be flashed? Any help is greatly appreciated!
OS device name: J:
Revision: 1.02
Serial number: ...
Hi, I have very similiar Drive, do you think it is also possible ?
It is in an Asus enclouser: ASUS TurboDrive BW-16D1H-U_PRO.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number: ****************
Firmware date: 2019-03-07
Highest AACS version: 53
Firmware version: E115/ID71
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
sure email meThomas K wrote: ↑Fri Jun 20, 2025 7:14 amHi, I have very similiar Drive, do you think it is also possible ?
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
