Bluray disc Galapagos BBC not ripping correctly
Makemkv v1.6.16 rips the disc Galapagos but resulting files do not play in VLC (or anything else). Sound track is Ok.
Stream 0 has type Windows Media Video VC1 (WVC1).
Other blu-ray discs rip Ok.
Re: Bluray disc Galapagos BBC not ripping correctly
VLC does not support VC-1. You will have to use another player. I believe SMPlayer supports it, but I'm not 100% sure.adsmith wrote:Stream 0 has type Windows Media Video VC1 (WVC1).
				setarip_old
 @adsmith
Hi!
Since you say that, "resulting files do not play in VLC (or anything else)", I'd suggest that you rip the disc again, with MakeMKV's logging turned on - and then submit the log...
						Hi!
What my original post should have said was:
What is it about the disc that causes makemkv to produce that type of output file?
As per request here is the debug file:
Debug log started at Mon Nov 21 19:58:42 2011 , written by MakeMKV v1.6.16 darwin(x86-release)
001005:0000 MakeMKV v1.6.16 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/adsmith/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL MATSHITA DVD-R UJ-85J FCQ5" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-RE HL-DT-ST BD-RE BP06LU10 HL03" opened in DASPI v1.3 mode.
DAFD=PAAAADAAAAEABDQkEGQEEAQ==
DCE=LKP1SlBWz1eBHkh8E6k489wzSvAOecZD/ib0qxAZXABOdn63oaZufX/VHUbXai3jQF5/aIidLOPNpplgW7u1zPUsC8v22ic7vh14I42tSKTpohSx+0Xds8l0lCuBp0uwTUhkbk9xSGcFJnpeSZaqBslrqc3+pa+6Bg==
DISCID=188F3471683FBFEE66F00456D23EE435CE97EA86
003307:0000 File 00001.m2ts was added as title #0
003307:0000 File 00002.m2ts was added as title #1
003307:0000 File 00003.m2ts was added as title #2
003309:0000 Title 00001.mpls is equal to title 00001.m2ts and was skipped
003309:0000 Title 00002.mpls is equal to title 00002.m2ts and was skipped
003309:0000 Title 00003.mpls is equal to title 00003.m2ts and was skipped
003025:0000 Title #00018.mpls has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00008.mpls is equal to title 00001.m2ts and was skipped
003309:0000 Title 00009.mpls is equal to title 00002.m2ts and was skipped
003309:0000 Title 00010.mpls is equal to title 00003.m2ts and was skipped
003025:0000 Title #00008.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 3 titles into directory /Users/adsmith/Movies/GALAPAGOS_UK
005001:0308 File /Users/adsmith/Movies/GALAPAGOS_UK/title00.mkv already exist. Do you want to overwrite it?
005001:0308 File /Users/adsmith/Movies/GALAPAGOS_UK/title01.mkv already exist. Do you want to overwrite it?
005001:0308 File /Users/adsmith/Movies/GALAPAGOS_UK/title02.mkv already exist. Do you want to overwrite it?
004001:0000 Forced subtitles track #3 turned out to be empty and was removed from output file
005005:0080 3 titles saved
005036:0104 Copy complete. 3 titles saved.
Application exited at Mon Nov 21 20:27:59 2011
My guess is that the video is 1080i, same as the HDDVD version.
Try using VLC's Codec info on the file and see what readings you get for the video stream. If it's 1080i then the file is fine, the problem is that VLC can't play 1080i.
VLC Media info reports
Stream 0
Type: Video
Codec: Windows Media Video VC1 (WVC1)
Language: English
Resolution:1920x1080
Frame rate: 29.970628
Stream 1
Type: Audio
Codec: A52 Audio (aka AC3) (a52)
Language: English
Channels: Stereo
Sample rate: 4800 Hz
Bitrate: 448 kb/s
Stream 2
Type: Subtitle
Codec: BD subtitles (bdpg)
Language: English
						Stream 0
Type: Video
Language: English
Stream 1
Type: Audio
Language: English
Channels: Stereo
Bitrate: 448 kb/s
Stream 2
Type: Subtitle
Language: English
Many thanks, problem solved.
Installed Flip4Mac so Quicktime player was able to read. Exported. Handbrake did the final tidy-up.
Oops! my error.
Sequence was:
1. install Flip4Mac;
2. Rip using MakeMKV;
3. Change wrapper using MPEG Streamclip;
4. change wrapper contents using QuickTime Player;
5. tidy-up using HandBrake.
long winded but it works!
Thanks again to all those who helped.
						Sequence was:
More specifically, VLC doesn't not support interlaced VC-1. But work is underway to add support to libavcodec, which means apps that use it like VLC will eventually be able to decode it.crowfax wrote:VLC does not support VC-1.adsmith wrote:Stream 0 has type Windows Media Video VC1 (WVC1).
AFAIK, the only software to support interlaced VC-1 are "official" Blu-ray playback software (PowerDVD etc.), software that has access to Microsoft's decoder (setarip_old should be able to answer that one) and Flip4Mac under OS X.crowfax wrote:You will have to use another player. I believe SMPlayer supports it, but I'm not 100% sure.
