MacOS 15.4 RC1 breaks Makemkv
Gilbert99
Fatal error popup when launched. App launches, but does not recognize disks.
Re: MacOS 15.4 RC1 breaks Makemkv
There is already an existing thread on the broken MacOS problems.
DavoBR
Yep, see here: viewtopic.php?f=4&t=37090
Gilbert99
Thanks. My workaround is to use Makemkv under Win 11 for ARM on Parallels. Seems to work so far
DavoBR
That could be my future workaround. Meanwhile, I'm sticking with 15.3.2 and not going near any MacOS Beta/RC.Gilbert99 wrote: Tue Mar 25, 2025 9:17 pm Thanks. My workaround is to use Makemkv under Win 11 for ARM on Parallels. Seems to work so far
Gilbert99
Feedback Assistant response from Apple states Change required from3'rd party
