I noticed with some of my very early 4k bluray rips I'd not encoded them with the Dolbyvision / HDR metadata passthrough correctly in handbrake, so I decided to re-rip and re-encode them correctly. Most worked fine except for 2.
Star Trek 4 The Voyage Home
Start Trek 10 Nemesis
I submitted the dumps as per the FAQ, but the question is, I've used these same physical discs and the same drive and makemkv to rip these discs when I bought them, why are they unknown now (yes the makemkv version is a little later, but that's it)
Checked the error log, it's not a blockage getting the decrypt data, it just thinks these cannot be decrypted, yet my earlier rips and encodes prove they are.
Just curious to how and why this could happen ?
Previous Working Discs - no longer working ?
DessieJerde
Re: Previous Working Discs - no longer working ?
If you were able to rip them before but can't now, it's possible that the key has been changed or removed by MakeMKV in recent updates. Check if there's a new update and update it.
VERY unlikely, compared to the possibility of disk contamination. MakeMKV keeps its keys separate from the program, and that list keeps growing.DessieJerde wrote: Mon Mar 24, 2025 1:28 am If you were able to rip them before but can't now, it's possible that the key has been changed or removed by MakeMKV in recent updates. Check if there's a new update and update it.
It's more likely that the disk, when stored in its housing, has picked up a "film" of contamination. Quite often, you can see that contamination by wiping a clean cloth across the case. Doing so with a proper microfiber cloth across the disk itself (always moving across the diameter of the disk, not circularly) can make it apparent, too. I clean disks that have been in their cases more than 6 months before I rip them. Sometimes, it's necessary when they're new, but usually it takes a few months to transfer.
darcym
that's really interesting, it must be ~6 months from when I last used the media, I'll give them a proper clean and see if it makes a difference, I'd not considered anything along those lines, thank you
darcym
big surprise, it worked, the discs looked clean, I'd given then a wipe, gave them a proper clean as you suggested, they both worked.
Great suggestion.
Great suggestion.
