Strange New Worlds Season Two
akacat
Post by akacat »
I don't know if these discs are even the issue, but I'm at my wits end.
PlayerFab x64 has no problem with them, on the same pc and bluray drive.
MakeMKV somehow worked on the first disc, after numerous reboots and reinstalls of makemkv. I don't know what, if anything, caused it to work. Maybe it was a fluke. But mostly MakeMKV is giving me one of two outputs when I try to scan the disk.
1 - the output looks like this. Note that titles 22,23 & 24 are legit, they're the ones that playerfab is able to play.
MakeMKV v1.17.9 win(x64-release) started
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MOEL4TC0901' at offset '0'
Title #4 has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 1-1 were removed from title start
Cells 7-7 were removed from title end
Title #22 declared length is 0:48:34 while its real length is 0:00:00 - assuming fake title
Title #23 declared length is 0:48:29 while its real length is 0:00:00 - assuming fake title
Title #24 declared length is 0:45:29 while its real length is 0:00:00 - assuming fake title
Title #33 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33/1 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33/2 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Or 2:
It displays "Failed to open disc", sometimes with bonus "Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.00 MOEL4TC0901' at offset '589824'" and "udf: node fe/efe failed!" thrown in. (The offset number varies, but 589824 seems to be pretty common.)
I sort of doubt that the drive is an issue, since again PlayerFab is having no problem with it at all. And, MakeMKV doesn't seem to have a problem reading my "Good Place" bluray discs.
Re: Strange New Worlds Season Two
That looks like a DVD. MakeMKV has different opening modes for DVDs that might help.
