BD-RE BU20N - Zeebbyee drive firmware update?
ohseb
Post by ohseb »
Hi I wondering if I should try to update the firmware on my external bluray/dvd drive.
It seems to run fine with some discs and not others.
Thanks in advanced.
This is the drive details from makemkv and the purchased amazon url below:
https://www.amazon.co.uk/dp/B08G81SWC6? ... ct_details
This is the details of my BD DVD drive in makemkv
OS device name: K:
Product: BD-RE BU20N
Revision: EB02
Serial number: ...
Firmware date: 2114-12-18 10:02
Bus encryption flags: 1F
Highest AACS version: 75
Firmware version: 0.EB02C
zittrig
Re: BD-RE BU20N - Zeebbyee drive firmware update?
Post by zittrig »
I think you can try firmware BU40N 1.00 or BP55EB40 1.00.
But please wait until another statement for your situation, I could be wrong.
ohseb
Post by ohseb »
Is there a way to backup the current firmware I have? I mainly use the Blu-ray drive to backup my 3D blurays for watching on my tv and in VR. Most discs have worked flawlessly except a couple of Disney discs (Brave and Cars).
Thanks again!
ohseb wrote:
Mon Mar 24, 2025 5:10 am
Thanks in advanced.
OS device name: K:
Revision: EB02
Serial number: ...
DO NOT TRY TO FLASH this drive. The MT1959 firmware is too old. Only drives from 2015 are supported and yours is from 2014.
ohseb
Post by ohseb »
Thanks for the warning!
Any drives recommended to replace my drive that would work flawlessly? Thanks! :D
