Smallville Season 6 (trouble ripping)
kimja215
Post by kimja215 » Mon Jul 14, 2014 1:51 am
I'm currently trying to rip Smallville Season 6 but it won't rip. Please help.
Re: Smallville Season 6 (trouble ripping)
Post by Woodstock » Tue Jul 15, 2014 3:59 am
Hint: "It doesn't work" makes it hard to help. Link in my signature will help us help you. You can post the log in your reply.
kimja215
Post by kimja215 » Tue Jul 15, 2014 8:32 pm
Sorry about that. The first episodes on each disc won't rip. Maybe this might help.
MakeMKV v1.8.10 darwin(x86-release) started
Optical drive "DVD+R-DL HL-DT-ST DVDRW GX30N RP09d" opened in OS access mode.
The new version 1.8.11 is available for download at /download/
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Title #1 was added (7 cell(s), 0:42:13)
Title #1/0/1 was added (7 cell(s), 0:42:07)
Title #1/0/2 was added (7 cell(s), 0:40:19)
Cells 8-end were skipped due to cell commands (structure protection?)
Title #2 was added (7 cell(s), 0:42:13)
Title #3 was added (7 cell(s), 0:42:07)
Title #4 was added (7 cell(s), 0:40:19)
Title #11 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/1 has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11/2 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13/1 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 was added (6 cell(s), 0:22:28)
Title #17 was added (1 cell(s), 0:03:31)
Title #18 was added (1 cell(s), 0:03:43)
Title #19 was added (1 cell(s), 0:02:59)
Title #20 was added (1 cell(s), 0:03:15)
Title #21 was added (1 cell(s), 0:04:35)
Title #22 was added (1 cell(s), 0:04:25)
Title #23 was added (3 cell(s), 0:09:08)
Title #24 was added (1 cell(s), 0:02:52)
Title #25 was added (1 cell(s), 0:03:45)
Title #26 was added (1 cell(s), 0:02:31)
Title #27 was added (5 cell(s), 0:09:50)
Title #28 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #30 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #32 was added (1 cell(s), 0:02:18)
Title #33 was added (2 cell(s), 0:02:22)
Title #34 has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 2 in VTS 1 is equal to title 1 and was skipped
Title 3 in VTS 1 is equal to title 1 and was skipped
Title 4 in VTS 1 is equal to title 1 and was skipped
Saving 1 titles into directory /Users/kimj469/Desktop
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '989184'
Post by Woodstock » Tue Jul 15, 2014 9:03 pm
You probably should update to 1.8.11, but that doesn't look to be the problem here. This is:
The drive says it can't read part of the disk. Things you can try:
Clean the disk. Yes, it may look clean, but there can be minor scratches that will interfere with the laser. I clean with spray furniture polish (Pledge brand works), because it cuts fingerprints, and fills in minor scratches. Soft cloth! I have special cotton towels I keep clean for that purpose, but others use cotton T-shirt scraps.
Increase the number of retries. Tools->IO, the default is 5. This tells MakeMKV to ask the operating system to try more times. Sometimes, it helps.
If you have a different disk drive, try it. The lasers in different drives have slightly different alignments; I have 3 BD and 4 DVD drives of various vintages for when the main ones can't read.
Sometimes, the disk is just bad. I had to get one disk replaced twice before it was readable, because the first two were from a batch with problems.
baileymb124
Post by baileymb124 » Sun Sep 08, 2024 4:28 pm
10 years after this thread started, I am now having the same issue.
Do you have a drive or drives that you'd suggest? My media server has a DVD drive, but I need to purchase a Blu-Ray Drive. If I could get a Blu-Ray Drive that is ALSO able to read this DVD, that would be great...
Thanks in advance.
mrswadge
Post by mrswadge » Fri Mar 21, 2025 4:07 pm
I had trouble with Disc 1 (episode 3) and Disc 2 (episode 6). All other episodes were fine. I tried EaseFab and it read it fine. I think it's a weakness in MakeMKV unfortunately.
mrswadge
Post by mrswadge » Mon Mar 24, 2025 9:22 am
I'm going to correct my above assertion. EaseFab cut out 10 minutes of video from Disc 1 - Episode 3, so I think actually my disks are wrecked :(
