Just bought the Jason Bourne box set, want to see it on Apple TV.
All three discs won't even load. It whirrs for a few minutes then spits the discs out. Have a sony Blu Rya reader, on a 2008 iMac, using OSX 10.7.2
Haven't had this issue with any other disc blu ray or DVD. Have converted 20 discs or so.
Any thought would be appreciated.
Bourne trilogy Blu Ray
Re: Bourne trilogy Blu Ray
Hi!
What does a problem with your original, purchased, comercial discs have to do with the beta testing of MakeMKV?
If, as you say, the box set that you just bought won't play, return them to the place of purchase.Just bought the Jason Bourne box set, want to see it on Apple TV.
Sorry if I wasn't clear enough. They all play fine on a stand alone Blu Ray. Player, but when I put them into an external blu ray reader, they won't read and get spat out. Any thoughts?
- Contact:
This is a known Mac problem, happens for some blu-rays. Launch MakeMKV, and then insert the disc.
Thanks, I thought I'd tried every combination of rebooting, inserting disc, opening MKV...
But I did as you said. Quit, opened MKV, re inserted disc and now the damn thing is loading.
