Also, it ignores any positive lift offset (values over 2048). Used in almost all movies...
if the movie constantly goes over 1000nits with a 1000nits MDL, yes.it is better to generate new DV metadata with higher MDL, right?
But what about the Mad Max Fury Road, since I cannot set MDL higher than 4000 in Davinci? Is it than better to watch it in HDR10?
No, the positive lift is often found in the 600-1000-nit trim, and the example I just posted is a 600-nit trim.Regarding the positive offset – isn’t it mostly used in 100-nit plots and thus doesn’t have much effect?
should be fixed now
Thanks, so from your experience, would it look better to watch it in DV with clipping or in just HDR10 without DV?RESET_9999 wrote: ↑Sun Mar 23, 2025 2:38 pmif it goes over 4000nits, there's nothing you can do about it, it will clip.
I don't know, it depends on your TV's handling of the static HDR10 metadata. On my C2, content over 1000nits with a 1000nits HDR10 MDL is also clipped.
Do I need to rerun the whole thing with different file name?RESET_9999 wrote: ↑Mon Mar 24, 2025 11:02 ammetafier doesnt allow some special characters in filename
