Epedemic
Post by Epedemic »
So, google decided to finally update the CCwGTV to Android 14. However, other than it being a totally botched update, it seems FEL support might be permanently gone, "thanks to" an upgrade to kernel 5.15. I can live with that, as I have a X700 as well, however I wonder if anyone can confirm wether MEL is still played correctly? (It looks like it to me, but I cannot verify it as well as the experts here can)
It doesnt matter because the GTV FEL playback is out of sync anyway and it does fake tv-led.
The x700 alters the metadata(not true TV-LED) and ignores any positive lift so get the ugoos if you want the best bug-free DV quality.
Epedemic
Post by Epedemic »
RESET_9999 wrote:
Wed Mar 19, 2025 2:23 pm
Well, I have an ancient TV (LG E6), so TV-LED is not for me yet.
pretty sure all the LG TV supports TV-LED and only a few early SONY models didn't.
Maybe you're confusing it with cmv4.0?
Since my next TV (G5) will be able to play most content without tone mapping, I thought it would be useful to list all the 4000-nit movie grades. So, I added two new tabs to my Google Drive Excel sheet:
1- movies brighter than 1000nits: https://docs.google.com/spreadsheets/d/ ... 1557834794
2- movies that are practically SDR in HDR container: https://docs.google.com/spreadsheets/d/ ... 1488998734
The dark grades list will be updated frequently over the next few days, as many movies are graded under 300 nits, and I'm still going through my library. For the bright grades list, I think I found most of them (about 200 titles)
powdeau
Post by powdeau »
If I want to check whether a x700 would alter metadata or not, I just just check if L1 plot values are lower than MDL value?
E.g. if all L1 values would be under 1000 nits and MDL is 1000, then it is OK?
So the only problem would be L1 over 1000 nits with MDL 1000 and L1 over 4000 with MDL 4000? And if that happens I just edit the MDL to higher value (e.g. edit Mad Max Fury Road to MDL 10 000)
Yes, any value over the MDL is ignored, and you cannot change the RPU MDL. Modifying it would make everything else inaccurate since Dolby calculates metadata differently based on the MDL.
Also, it ignores any positive lift offset (values over 2048). Used in almost all movies...
powdeau
Post by powdeau »
So if the L1 values are higher than MDL, it is better to generate new DV metadata with higher MDL, right?
But what about the Mad Max Fury Road, since I cannot set MDL higher than 4000 in Davinci? Is it than better to watch it in HDR10?
Regarding the positive offset – isn’t it mostly used in 100-nit plots and thus doesn’t have much effect?
BTW Haven’t you changed something in your "Chroma Weight Bug" sheet, since I cannot scroll there anymore?
if the movie constantly goes over 1000nits with a 1000nits MDL, yes.
if it goes over 4000nits, there's nothing you can do about it, it will clip.
No, the positive lift is often found in the 600-1000-nit trim, and the example I just posted is a 600-nit trim.
Even if the positive lift were only in the 100-nit trim, the problem would still exist because the metadata is always extrapolated to any brightness target.
powdeau wrote:
Sun Mar 23, 2025 1:44 pm
should be fixed now
powdeau
Post by powdeau »
RESET_9999 wrote:
Sun Mar 23, 2025 2:38 pm
Thanks, so from your experience, would it look better to watch it in DV with clipping or in just HDR10 without DV?
powdeau wrote:
Sun Mar 23, 2025 2:50 pm
I don't know, it depends on your TV's handling of the static HDR10 metadata. On my C2, content over 1000nits with a 1000nits HDR10 MDL is also clipped.
Just get a Ugoos instead, it's 10 times better than the x700.
powdeau
Post by powdeau »
Do you please have a clipping test in profile 7? Because when I tried your clipping pattern in profile 5, there was no clipping on x700.
powdeau
Post by powdeau »
Sorry for the wrong information, I have tested only the 1000 MDL file, which doesn't clip in any profile. The 2000 and 4000 do clip.
But it is still weird that the 1000nits MDL doesn't clip.
you tested the wrong files or confused the filename.
white clipping 1000nits MDL (clipped at 1000nits): https://drive.google.com/file/d/1qQPnuB ... drive_link
white clipping 4000nits MDL (clipped at 4000nits): https://drive.google.com/file/d/1zzcrqy ... drive_link
white clipping 10 000nits MDL (no clipping): https://drive.google.com/file/d/10OT1bg ... drive_link
real content (clipped): https://drive.google.com/file/d/1QCxaJU ... drive_link
