Success! Again, thank you very much for this. For me and anyone else who purchased this drive under the presumption that it would support UHD BR discs out of the box.Coopervid wrote: Sat Mar 15, 2025 7:30 pmPM sent.MattRyx wrote: Sat Mar 15, 2025 3:47 pm @Coopervid,
Hello. I am re-requesting your assistance with unlock firmware for this drive. MakeMKV drive details as follows:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8511
Firmware version: 1.14
Thank you very much in advance for your assistance. The stack of waiting 4K vids is slowly growing.![]()
Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
MattRyx
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
JerekMars
@Coopervid
Hi i am also need your assistance with the Firmware unlocking of my drive
Revision: 1.10
Firmware-date: 2017-04-18
Bus-encryption flags: 1B
Highest AACS version: 19
Firmware version: 1.10
Thank you
Revision: 1.10
Thank you
jdfire
Been using Make MKV and very pleased with it, wondering if my drive can aslo be flashed to read 4k blu rays?
Current profile: DVD-ROM
Revision: 1.14
Serial number: ...
Revision: 1.14
Serial number: ...
Maniac1983
Hi Coopervid,
can you help me as well? Thank you very much!
Revision: 1.14
Serial number: ...
Highest AACS version: 76
Revision: 1.14
Serial number: ...
Titanic
Dear Coopervid,
Would you please be willing to help out in making my drive able to read UHD discs? Thank you so much for your time.
Sincerely,
Titanic
Revision: 1.14
Firmware-date: 2020-06-15
Sincerely,
Titanic
Revision: 1.14
PM sent.JerekMars wrote: Tue Mar 18, 2025 8:33 pm @Coopervid
Revision: 1.10
Thank you
PM sent.jdfire wrote: Fri Mar 21, 2025 3:54 pm Hello,
Revision: 1.14
Serial number: ...
PM sent.Maniac1983 wrote: Sat Mar 22, 2025 10:50 am Hi Coopervid,
Revision: 1.14
Serial number: ...
PM sent.Titanic wrote: Mon Mar 24, 2025 8:28 pm Dear Coopervid,
Sincerely,
Titanic
Revision: 1.14
Maniac1983
Unfortunately I haven’t received your PM.
Revision: 1.14
Serial number: ...
Stellavision
I have the Verbatim 43889 which I had hoped would read UHD disks out the box, but MakeMkv shows no disk.
I thought I'd done my research on the best drives to get for UHD compatibilty with mkv conversion, but clearly not enough! smh
Looks like its a Pioneer drive:
OS device name: F:
Revision: 1.14
Serial number: ,,,
Highest AACS version: 62
Google isn't helping massively, so hoping some clever people on here might be able to point me in the right direction of finding the relevent info to fix this.
OS device name: F:
Revision: 1.14
Serial number: ,,,
Stellavision
I’ve posted similar on a separate thread, but it’s probably appropriate to post here as well. I have just read that it’s actually the Verbatim 43888 which is 4K compatible and the 43889 is not, so I think I might have to return it.Stellavision wrote: Thu Mar 27, 2025 9:03 pm I have the Verbatim 43889 which I had hoped would read UHD disks out the box, but MakeMkv shows no disk.
OS device name: F:
Revision: 1.14
Serial number: ,,,
PM sent.Stellavision wrote: Thu Mar 27, 2025 9:03 pm I have the Verbatim 43889 which I had hoped would read UHD disks out the box, but MakeMkv shows no disk.
OS device name: F:
Revision: 1.14
Serial number: ,,,
Stellavision
Thanks Coopervid. I’ve just replied.
