Godfather Trilogy - Coppala Restoration
Jsbulger
Having an issue with just DISC 1. I was able to get Disc 2 & 3, but Disc 1 errors out every time. I searched the forum for the hash check error, but that just says I have a bad Driver, which I know I do not, since it is working for a bunch of other BDs, just not this one disc. I have attached a TXT of the output from the MakeMKV application.
Re: Godfather Trilogy - Coppala Restoration
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 6167451648, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00000.m2ts' (title #-) , future messages will be printed only to log file
Failed to save title 0 to file C:/Users/jared/Downloads/MKVs/The Godfather_t00.mkv
Encountered 243 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failedI'd be suspicious that all the read problems were at a large offset from the beginning of the disk. There are places where the disk transitions between layers, which can be sensitive to dirt/contamination.
nwest15
Where you able to find a solution? I am having the same issue.
Jsbulger
I waited a few months, tried again and it just worked. I'm not sure exactly what caused it to finally work.
bigben
I'm getting the same issue. Brand new Blu-ray, still had the plastic around the case before I loaded it into the drive. The discs for Part 2 and 3 worked fine. I can play Part 1 on my PS4 just fine. I've tried cleaning the drive and reading it on both Mac and Windows, but the issue persists.
These two errors over and over in the logs:
MakeMKV v1.18.2 darwin(arm64-release)
Apple M1 chip
macOS Sequoia 15.7.3
LG BP50NB40 NB52 drive
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '24158797824'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '24158797824'Apple M1 chip
OS device name: /dev/rdisk5
Current profile: DVD-ROM
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIK0CPALF3241
Firmware date: 2121-07-08 16:03
Highest AACS version: 50
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Unrestricted read speed: Possible (with patched firm-
bigben
Tried ripping the disc for Part 1 again today after wiping off the disc with a microfiber cloth again and this time it finally worked. The disc looked just as clean this time as it did the other time after I tried cleaning it so not sure if there was just something on it I couldn't see or what. Same drive, same firmware, same OS version, same version of MakeMKV.
