barto_olli
Post
by barto_olli » Tue Mar 18, 2025 12:11 pm
Hi Coopervid ( @Coopervid )
Is it possible to update ASUS drive (SBW-06D5H-U) based on platform RS8511(PIONEER BDR-US03) so that it works with UHD discs?
I'd appreciate it if you help me with this problem.
Thank you.
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: BCDLxxxxxxxx
Firmware date: 2018-08-22
Drive platform: RS8511
Firmware version: E101/ID26
pnlx1
Post
by pnlx1 » Tue Mar 18, 2025 9:34 pm
Hi @coopervid, thank you for your excellent support and contribution to the forum.
I have an ASUS SBW-06D2X-U opened the enclosure and found a Pioneer BDR-UD03ASW labelled drive.
Info on MKV is as follows:
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: ...
Firmware date: 2017-04-18
Highest AACS version: 76
Firmware version: ID22
Can you please support me into patching and unlocking the UHD capability please (e.g. crossflash to UD04 if possible)?
Many thanks in advance.
hannes.s
Post
by hannes.s » Sat Mar 22, 2025 12:23 am
I'm new to this and started only two days ago with saving my blu-rays.
Bought the 43889 with the intend to use it with UHD discs aswell.
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer:
Firmware-Datum: 2020-06-15
Highest AACS version: 66
Firmware version: 1.14
Thanks alot
DefinitelyNotSade
Post
by DefinitelyNotSade » Mon Mar 24, 2025 10:37 pm
Hi Coopervid, or anybody that can help!
I have a Verbatim LPUBAA external drive with the following details:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.11
Serial number: [redacted]
Firmware date: 2018-11-28
Highest AACS version: 65
Firmware version: 1.11
Would love to be able to rip UHD discs if it's possible with this drive!
Post
by Coopervid » Tue Mar 25, 2025 11:30 am
pnlx1 wrote: Tue Mar 18, 2025 9:34 pm
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM sent.
Post
by Coopervid » Tue Mar 25, 2025 11:32 am
hannes.s wrote: Sat Mar 22, 2025 12:23 am
Produzent: PIONEER
Revision: 1.14
Serienummer:
Thanks alot
PM sent.
Post
by Coopervid » Tue Mar 25, 2025 11:33 am
DefinitelyNotSade wrote: Mon Mar 24, 2025 10:37 pm
OS device name: F:
Revision: 1.11
PM sent.
Post
by Coopervid » Tue Mar 25, 2025 11:39 am
barto_olli wrote: Tue Mar 18, 2025 12:11 pm
Thank you.
Manufacturer: ASUS
Revision: E101
PM sent.
pnlx1
Post
by pnlx1 » Thu Mar 27, 2025 8:23 am
Coopervid wrote: Tue Mar 25, 2025 11:30 am
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM sent.
Many thanks for your support, drive has been unlocked.
PS: Check your mailbox
Thanks again.
mk_0x43
Post
by mk_0x43 » Thu Mar 27, 2025 12:55 pm
OS device name: /dev/sr0
Revision: 1.11
Serial number: ...
Highest AACS version: 81
Hello, I have the same behavior, with this reader and firmware - any possible solution?
mhunt407
Post
by mhunt407 » Thu Mar 27, 2025 3:26 pm
Hi! Stumbled upon this thread after a quick google. Is it possible to enable UHD? Thanks!
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Stellavision
Post
by Stellavision » Thu Mar 27, 2025 6:07 pm
I'm new here and I've literally just received a Verbatim drive today with a view to setting up a home media server.
The drive shows as a Pioneer BDR-UD03, same as the post above and won't read 4K bluerays when inserted.
Is there a patch available for this please?
OS device name: F:
Revision: 1.14
Serial number: ...
Highest AACS version: 62
Stellavision
Post
by Stellavision » Fri Mar 28, 2025 12:12 am
Stellavision wrote: Thu Mar 27, 2025 6:07 pm
OS device name: F:
Revision: 1.14
Serial number: ...
I think I might actually return this.
It’s actually the Verbatim 43889 and I have just read that I would need the 43888 for 4k compatibility.
Post
by Billycar11 » Fri Mar 28, 2025 12:33 am
Stellavision wrote: Fri Mar 28, 2025 12:12 am
OS device name: F:
Revision: 1.14
Serial number: ...
nah email me thats the better one now they changed the 43888 to a junky lg now
wallybuys
Post
by wallybuys » Sun Mar 30, 2025 2:34 am
I have had a Pioneer BDR-UD03FAL sitting around, I managed to get a case for it. It looks like I need to cross flash it (to a UD04?) in order for it to read Blu-Rays?
See attached MakeMKV output, and I have a PC to do any required flashing.
OS device name: /dev/sr2
Revision: 1.03
Serial number:
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
