I've recently upgraded to 4k monitors and I'm running Windows 11 with the latest release of MakeMKV (v1.17.9). I've got the scaling set to 150% and all my other apps/windows are fine, it's only MakeMKV where the text is super tiny. I can increase the text size in the bottom log section by holding Ctrl and moving the scroll wheel, but I cannot find anything to increase the text size for the left and right sections.
Was wondering if anyone else is having this issue or has found a solution. The screenshot makes the text look bigger than it actually is on the monitor.
Text scaling on 4k monitor on MakeMKV itself
oobedoob
Re: Text scaling on 4k monitor on MakeMKV itself
Right click the Makemkv icon. Choose "Properties", "Compatibility" "Change High DPI settings".
oobedoob
Looks like that worked. Used this option and the text is coming up much larger now.Coopervid wrote: Mon Mar 17, 2025 10:36 am Right click the Makemkv icon. Choose "Properties", "Compatibility" "Change High DPI settings".
