Text scaling on 4k monitor on MakeMKV itself
oobedoob
Post by oobedoob »
I've recently upgraded to 4k monitors and I'm running Windows 11 with the latest release of MakeMKV (v1.17.9). I've got the scaling set to 150% and all my other apps/windows are fine, it's only MakeMKV where the text is super tiny. I can increase the text size in the bottom log section by holding Ctrl and moving the scroll wheel, but I cannot find anything to increase the text size for the left and right sections.
Was wondering if anyone else is having this issue or has found a solution. The screenshot makes the text look bigger than it actually is on the monitor.
Re: Text scaling on 4k monitor on MakeMKV itself
Right click the Makemkv icon. Choose "Properties", "Compatibility" "Change High DPI settings".
oobedoob
Post by oobedoob »
Coopervid wrote: Mon Mar 17, 2025 10:36 am Right click the Makemkv icon. Choose "Properties", "Compatibility" "Change High DPI settings".
Looks like that worked. Used this option and the text is coming up much larger now.
