ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
Recovery flash from 16D1HT to BU40N 1.03MK I've wrote. Means the 1.03MK is the final firmware because the BU40N is the drive in this ASUS enclosure.
Check 4k with the 1.03MK.
Yes, please send next PM. Thank you!
Can someone help me make my drive UHD compatible?
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: ...
Firmware date: 2023-04-20
Firmware version: ID26
Manufacturer: ASUS
Revision: E102
Serial number: ...
Regrettably, thanks to Pioneer, that can't happen (to date?).Antihero wrote: Fri Feb 21, 2025 12:50 pm Can someone help me make my drive UHD compatible?
Manufacturer: ASUS
Revision: E102
Serial number: ...
OS device name: F:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: ...
Firmware date: 2017-04-18
Firmware version: ID22
Seems to be LibreDrive compatible & old enough firmware. Thanks for any assistance on the correct firmware to use.
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM sent.suivulP wrote: Tue Feb 25, 2025 3:38 pm Drive Information
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Dademurph74
Just picked this drive up in hopes that it can do UHD. I have 2 others that are too old.
I hope it's possible haven't seen any with this particular Firmware Date:
OS device name: J:
Manufacturer: ASUS
Revision: A102
Serial number: ***********
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Highest AACS version: 47
OS device name: J:
Manufacturer: ASUS
Revision: A102
This is a LG drive and needs to be flashed with LG firmware. See post on previous page by NotitaPls and zittrig's answer.Dademurph74 wrote: Thu Mar 06, 2025 2:51 am Just picked this drive up in hopes that it can do UHD. I have 2 others that are too old.
OS device name: J:
Manufacturer: ASUS
Revision: A102
Hi Coopervid, keen to upgrade this drive to libredrive firmware. Thanks in advance.
Manufacturer: ASUS
Product: SBC-06D2X-U
Revision: 1.10
Serial number:
Highest AACS version: 66
Drive platform: RS8591
Firmware version: 1.10/ID22
Manufacturer: ASUS
Revision: 1.10
Serial number:
PM sent.dsr566 wrote: Fri Mar 07, 2025 11:39 pm Hi Coopervid, keen to upgrade this drive to libredrive firmware. Thanks in advance.
Manufacturer: ASUS
Revision: 1.10
Serial number:
Hello. For Cooper that seems to help a lot of people, could you DM me as well with the Libredrive info? Thanks in advance.
Manufacturer: ASUS
Revision: 1.10
Serial number: ---
Highest AACS version: 81
Manufacturer: ASUS
Revision: 1.10
Serial number: ---
PM sent.lbr5539 wrote: Sat Mar 15, 2025 4:45 pm Hello. For Cooper that seems to help a lot of people, could you DM me as well with the Libredrive info? Thanks in advance.
Manufacturer: ASUS
Revision: 1.10
Serial number: ---
Hi! Can someone help me to flash my drive to Libredrive friendly firmware? Thanks in advance!
This is the makemkv info:
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
Firmware version: ID22 Re: ASUS SBW-06D2X-U
PM sent.Axelbcn wrote: Sun Mar 16, 2025 7:03 pm Hi! Can someone help me to flash my drive to Libredrive friendly firmware? Thanks in advance!
Drive Information OS device name: H: Manufacturer: ASUS Product: SBW-06D2X-U Revision: 1.10 Serial number: ... Firmware date: 2017-04-18 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8511 Firmware version: ID22
It has worked as expected.PM sent.
Small donation sent. Thank you very much.
