HotFudge
Post by HotFudge » Sat Mar 15, 2025 6:38 am
Hi Reset
Quick question regarding NVidia Shield Pro w.r.t v2.9 and v4.0
Resolve generates automatic L2 100,600,1000 v2.9 compatible trims
but the L8 100 trim equivalent in v4.0 is "empty" (set to 2048).
Will my Shield Pro take the L2 trims? or does it use the "empty" L8 trim.
Post by RESET_9999 » Sat Mar 15, 2025 12:50 pm
HotFudge wrote: Sat Mar 15, 2025 6:38 am Hi Reset
If your TV also supports cmv4.0, it won't use the L2 trims. The generated cmv2.9 L2 trims are here just to match the newer/updated cmv4.0 algo on cmv2.9 devices; you don't want your player/TV to use them.
see: https://www.youtube.com/watch?v=15HTaR0hRvI
HotFudge
Post by HotFudge » Sat Mar 15, 2025 2:52 pm
Hi Reset
Thanks for your answer
So the L8 trim is used to make manual adjustments to the L2 trims
which are used aslong as it is all in v4.0.
Do you also maintain a list of v2.9 and v4.0 devices and TV's
Post by RESET_9999 » Sat Mar 15, 2025 3:07 pm
No, but any hardware made after 2019 should have the cmv4.0 engine
HotFudge
Post by HotFudge » Sat Mar 15, 2025 3:38 pm
RESET_9999 wrote: Sat Mar 15, 2025 3:07 pm No, but any hardware made after 2019 should have the cmv4.0 engine
Many Thanks
deadchip12
Post by deadchip12 » Sat Mar 15, 2025 4:28 pm
@RESET_9999
I just did the transfer of cmv4.0 for the movie The Iron Claw (2023). Frame difference is +574. Seems pretty high. Other than that, watched the movie and there wasn't any problem.
Post by RESET_9999 » Sat Mar 15, 2025 5:41 pm
deadchip12 wrote: Sat Mar 15, 2025 4:28 pm @RESET_9999
it doesn't matter how big the frame difference is. It's fine as long as your source scene cuts are in sync.
ragico
Post by ragico » Sat Mar 15, 2025 6:58 pm
@Reset_9999
Thanks very much for your hard work and help, You are among the very few men who really helps.
Post by RESET_9999 » Sat Mar 15, 2025 7:25 pm
You're welcome :)
deadchip12
Post by deadchip12 » Sun Mar 16, 2025 6:52 am
@RESET_9999
I just watched your corelect configuration tutorial. Why is L6 set to Discard instead of Source?
Post by RESET_9999 » Sun Mar 16, 2025 10:33 am
L6 is useless
HotFudge
Post by HotFudge » Sun Mar 16, 2025 12:42 pm
RESET_9999 wrote: Fri Feb 28, 2025 10:40 pm yes, L2 is always ignored with a cmv4.0 RPU + hardware, even without L8.
Hi Reset
So does this mean in order to use my generated DaVinci Resolve RPU
I need to save it as v2.9 for it to use the L2 generated trims since
if I save the RPU as v4.0 it will just use the "empty" L8 v4.0 trim and
ignore the L2 generated v4.0 trims?
Post by RESET_9999 » Sun Mar 16, 2025 1:37 pm
No, as I said, the generated L2 trim is meant to mimic the improved tone mapping of CMv4.0 on CMv2.9 devices.
CMv4.0 L1 + L3 is roughly equivalent to CMv2.9 L1 + L2.
HotFudge
Post by HotFudge » Sun Mar 16, 2025 2:50 pm
RESET_9999 wrote: Sun Mar 16, 2025 1:37 pm No, as I said, the generated L2 trim is meant to mimic the improved tone mapping of CMv4.0 on CMv2.9 devices.
Ah sorry RESET.
I think I get it now
For cmv4.0
if L8 is empty then it will use L1+L3 generated metadata otherwise it will use L1+L8.
Thanks very much for your continue help.
Post by RESET_9999 » Sun Mar 16, 2025 2:55 pm
if L8 is active, it will use L1+L3+L8. Check out these metadata video comparisons: https://drive.google.com/drive/folders/ ... dMiy2ka0mf
