ragico
Post by ragico » Sat Mar 15, 2025 6:58 pm
@Reset_9999
Thanks very much for your hard work and help, You are among the very few men who really helps.
Post by RESET_9999 » Sat Mar 15, 2025 7:25 pm
You're welcome :)
deadchip12
Post by deadchip12 » Sun Mar 16, 2025 6:52 am
@RESET_9999
I just watched your corelect configuration tutorial. Why is L6 set to Discard instead of Source?
Post by RESET_9999 » Sun Mar 16, 2025 10:33 am
L6 is useless
HotFudge
Post by HotFudge » Sun Mar 16, 2025 12:42 pm
RESET_9999 wrote:
Fri Feb 28, 2025 10:40 pm
yes, L2 is always ignored with a cmv4.0 RPU + hardware, even without L8.
Hi Reset
So does this mean in order to use my generated DaVinci Resolve RPU
I need to save it as v2.9 for it to use the L2 generated trims since
if I save the RPU as v4.0 it will just use the "empty" L8 v4.0 trim and
ignore the L2 generated v4.0 trims?
Post by RESET_9999 » Sun Mar 16, 2025 1:37 pm
No, as I said, the generated L2 trim is meant to mimic the improved tone mapping of CMv4.0 on CMv2.9 devices.
CMv4.0 L1 + L3 is roughly equivalent to CMv2.9 L1 + L2.
HotFudge
Post by HotFudge » Sun Mar 16, 2025 2:50 pm
Ah sorry RESET.
I think I get it now
For cmv4.0
if L8 is empty then it will use L1+L3 generated metadata otherwise it will use L1+L8.
Thanks very much for your continue help.
Post by RESET_9999 » Sun Mar 16, 2025 2:55 pm
if L8 is active, it will use L1+L3+L8. Check out these metadata video comparisons: https://drive.google.com/drive/folders/ ... dMiy2ka0mf
HotFudge
Post by HotFudge » Sun Mar 16, 2025 3:38 pm
RESET you are MVP
Thanks again
HotFudge
Post by HotFudge » Sun Mar 16, 2025 7:19 pm
L6 is useless
why is this metadata useless?
Post by RESET_9999 » Sun Mar 16, 2025 7:40 pm
it's not used in DV
HotFudge
Post by HotFudge » Mon Mar 17, 2025 6:48 pm
it's not used in DV
Interesting. Thanks
deadchip12
Post by deadchip12 » Mon Mar 17, 2025 11:29 pm
it's not used in DV
Hmm then what's the point of making it a setting in cpm build?
Post by RESET_9999 » Tue Mar 18, 2025 1:11 am
For the same reason my scripts automatically edit it when injecting XML even though it's useless, why not?
Just enable it if it makes you feel better...
Epedemic
Post by Epedemic » Wed Mar 19, 2025 3:06 am
So, google decided to finally update the CCwGTV to Android 14. However, other than it being a totally botched update, it seems FEL support might be permanently gone, "thanks to" an upgrade to kernel 5.15. I can live with that, as I have a X700 as well, however I wonder if anyone can confirm wether MEL is still played correctly? (It looks like it to me, but I cannot verify it as well as the experts here can)
